Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-22-2015 | 08:54 AM
  #7891
shein95's Avatar
getting my first nova this week. really looking forward to trying one out.
shein95 is offline
Old 06-22-2015 | 03:28 PM
  #7892
bash bros's Avatar
Default p5xlt plugs?
So, I'm gonna expand my glow plug collection a little bit since all I have on hand is a couple c5's and c6's for the p5xlt.
I ordered a couple 97t's that were on sale at Amain, but wondering what else I should get.
77t? c7tgc? It gets pretty hot and humid in the summer, and towards the end of the racing season it can get pretty cold so I just want to have all my bases covered. I'm running 30/11 byron's and a 053 pipe.
bash bros is offline
Old 06-22-2015 | 07:22 PM
  #7893
cczjordan's Avatar
C6 will be perfect but not sure bout OD
cczjordan is offline
Old 06-22-2015 | 07:41 PM
  #7894
Suspended
Socket is offline
Old 06-23-2015 | 02:58 PM
  #7895
KyoshoRed's Avatar
Have a lot of you used Avid bearings for front and rear bearings in your motors? If so,how good at they? Got a motor that needs rebuilding and got a hookup on some Avid ceramic bearings but wondering how good or bad they are. Asking bout Avid ceramic motor bearings specifically.
KyoshoRed is offline
Old 06-23-2015 | 04:13 PM
  #7896
shein95's Avatar
I haven't got my motor yet but Neil at the nitro shop uses the avid ceramics as an option for the rear bearing in his modified motors.
shein95 is offline
Old 06-23-2015 | 04:24 PM
  #7897
fizzy's Avatar
Has anyone had any experience with or have any knowledge of the 24066 carb - I believe this carb has the hi speed needle horizontal and am just wondering how this would effect tuning and such?
fizzy is offline
Old 06-23-2015 | 05:00 PM
  #7898
Maximo's Avatar
actually your engine doesn't have a Avid in it...I was too slow making my Avid order so instead I used a replacement Hudy ceramic bearing..... Its a more expensive bearing but its not your worry ! ...real deal swiss bearing in her now !!!
Maximo is offline
Old 06-23-2015 | 05:20 PM
  #7899
shein95's Avatar
Oh cool. That's awesome, thanks Neal.
shein95 is offline
Old 06-23-2015 | 05:45 PM
  #7900
sn47som1's Avatar
Please help with clutch/pipe/header!
I am running a modded 7 port Nova, so a lot of power in buggy!! maybe too much...
Im running 9886ss/41001 with a new BUKU clutch just at about factory settings maybe a hair softer on spring tension. The power comes on like a damn light switch even with the staggered spring settings and a controlled progressive throttle finger. I have to try really hard to get the power down and smooth thru out the powerband. Im thinking its the pipe/header combo but not sure. But I love the top end the combo gives me and the power everywhere else too but its a light switch which is awful for driving. Any other pipe combos to try for driveability AND torque/rpm? Thank you peoples!!
sn47som1 is offline
Old 06-23-2015 | 07:53 PM
  #7901
Hoese37's Avatar
Odonnell 97T are the same as C6 plugs. To be honest unless you are running youre engine in an extreme climate change, theres no need to change heat ranges. Here in MN, we race when its 100+ out, to about 20.
Ive used the rear bearing, but would rather use the Nova double seal or the OS speed bearing in the front.
Hoese37 is offline
Old 06-23-2015 | 08:15 PM
  #7902
Yeah.. all I'm just going to quote Monty Houston.. "ooooh boooooiii..."
Modded 7 port nova, and then you run the craziest truggypipe setup
First you need to get rid of the 41001 manifold. That manifold shifts the powerband so that you get what you call the lightswitch effect, which would be great if you were running a standard BTT, but you've got a modded 7 port
Then you need to get rid of the 9886. That's also a crazypipe.
Basicly you need to get a more restrictive pipe and manifold setup which will smoothen out the power delivery. So you want the 41021/41029 manifold, 029 is the Mugen version, if you run a Mugen that is the one that fits.
Then you probably want to go to something like a 2096 pipe.
You might be wanting to go to 0.9 springs and plastic clutch shoes, and something like a 6 or 6.5 venturi, if you are on 8 now, 6.5 would probably help as a first step.
Eivind E is offline
Old 06-23-2015 | 08:40 PM
  #7903
cczjordan's Avatar
Basically i use this setup, only different is 8mm venturi. Guess u will need a steel flywheel s well
Old 06-23-2015 | 11:43 PM
  #7904
sn47som1's Avatar
I run the 8mm venturi. I figured I could clutch the power "down" with a soft setting but maybe I need to change exhaust too and go back to a 7.5mm and 021 header like before but i hate to lose power ... decisions decisions lol
thanks for the help!!
sn47som1 is offline
Old 06-24-2015 | 05:53 AM
  #7905
Have a new P5XLT...I had gotten some O'Donnell 97t after reading a bunch of good reviews on this plug with this motor. Then I went back a few years in this thread and saw that the Nova C6TGC were better suited for this motor...what is everyone thoughts?
MikeTinCT is offline
