Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-13-2012 | 06:12 AM
  #3886
ali_g's Avatar
Guys,
im new to Novarossi, will the Novarossi PLUS21 4C Team Off-Road Engine or Novarossi S21P5XLT .21 5 Port be suitable for a greenhorn?
ali_g is offline
Old 09-13-2012 | 06:22 AM
  #3887
Tran901's Avatar
has anyone ever ran a Plus 4 or modified plus 4 in a Truggy? is it lacking power?
Tran901 is offline
Old 09-13-2012 | 06:27 AM
  #3888
aznitronut's Avatar
Not yet for me, give me about 2 weeks, mine should be ready to go.
aznitronut is offline
Old 09-13-2012 | 07:02 AM
  #3889
Asharus's Avatar
Originally Posted by chopper82p
Blip the throttle right after he closes the tank before he puts the car down.
thanks will give that a try too.
Asharus is offline
Old 09-13-2012 | 07:13 AM
  #3890
Originally Posted by Asharus
ive been flaming at the pits after a fuel stop in my last 2 outings.
1. pit stop flame outs are usually the result of loading up too much fuel
2. your idea of replacing the fuel tank is a good one
3. make sure your pit man does not overfill the tank, and have him push the fuel tank lid down so it seals, after he refuels you
4. you said you already tried leaning out the bottom, now, does it run well on idle? By that I mean, can you sit and idle for 20 seconds, or does it flame out once you hit the throttle after some idling? if so you are probalby still too rich on bottom (and maybe idle gap too large), keep in mind that small adjustments can help a whole lot.
Eivind E is offline
Old 09-13-2012 | 07:39 AM
  #3891
Asharus's Avatar
thanks, yes the LSN is set lean enough so it doesnt get bogged down with fuel for at least 15 -20 seconds. the idle is very good and it idles forever and doesnt flame out if i hit the throttle after some idling. the only times i've flamed out are immediately after a pit stop, right after my pitman sets it down.
edit: i forgot to mention, the C6 plug i have on it probably has almost a gallon on it.... i was going to put a plug in on my next outing just to make sure that's not the issue. i know sometimes the bottom coil of the plug will no longer be hot enough after a while.
Asharus is offline
Old 09-13-2012 | 08:51 AM
  #3892
where can i get the tech spec for novarossi tune pipe and manifolds
yollie is offline
Old 09-13-2012 | 10:33 AM
  #3893
Moustik's Avatar
Ok, Just figured out "cosmetic" differences between Novarossi Off-Road carburetors.
24063 : Pretty standard on OR engines by now...
24069 : Note the metallish bottom end. Seem to be a metal body with surround plastic. I got this one on my new P5 2012.
24065 : Latest carburetor. According to Novarossi, it's like the 24063 but with 7mm inner diameter instead of 9mm on the 24063.
All my Novas came with 24063 except the new P5 I just bought couple days ago. Tomorrow I'm going to breakin, will see if this carb help or not tuning.
Any feedback appreciated !!!
Regards......
Moustik is offline
Old 09-13-2012 | 10:51 AM
  #3894
Maximo's Avatar
my Clocked Plus4 is very very strong....more then capable of hauling a truggy with authority.......
+ YouTube Video
Maximo is offline
Old 09-13-2012 | 12:26 PM
  #3895
Lille-bror's Avatar
Flames can also be caused by a little too rich HSN. Our pro engine really needs a perfect tuning to run smoothly. 95% of all flames is a fault-40 and/or wrong/faulty glowplug.
Lille-bror is offline
Old 09-13-2012 | 03:23 PM
  #3896
i have seen +4 in truggy and they do just fine, they dont need to be time pieced or whatever to power a truggy.
RePeTe is offline
Old 09-13-2012 | 03:29 PM
  #3897
Suspended
I've seen tons of stock +4's in truggies and Im not that impressed, I think the P5 in truggy would be a lot better.
Clocked +4 would be awesome in a truggy I would imagine.
rcuser567345 is offline
Old 09-13-2012 | 04:06 PM
  #3898
sschultz's Avatar
sschultz is offline
Old 09-13-2012 | 04:36 PM
  #3899
Tran901's Avatar
"time pieced" haha, Clocked motors from what i see are awesome...i may have to have my +4 "time pieced!"
Tran901 is offline
Old 09-13-2012 | 05:22 PM
  #3900
kgombe's Avatar
ran a stock 1 years ago and it was fine... it worked for me.. but a P5 will be better and its cheaper.. no need to modify
kgombe is offline
