ALPHA OFF ROAD ENGINES
#9841
So I'm trying to decide which clutch to throw on the A352. I have a Mugen stock, AE stock, Hot Bodies D812 carbon stock, a Fioroni Vario 3-shoe(great clutch FYI..), and a stock 4-shoe Werks. The local track has very little traction.. Would the carbon clutch just be a bad idea?
This .23 btw is being something of a .. let's say "minor challenge" to tune. Nothing bid-deal, but not particularly easy. It seems to literally take a tank and a half to decide on a tune for itself.. (i.e. after a tank, and maybe the last quarter of it running fine, it'll seem to change and need another tweak... I'm not sure it's just an end-of-tank lean thing either.. Just seems to wander..) Should I maybe throw in this other LSN or something, or are these just break-in hiccups? (About 12-14 tanks through it now...)
#9842
Guest
#9843
With the plug out I can turn it over with relative ease..
#9844
New engines will during some point go rich and the tune will change when they loosen up during break in but it does not go back and forth.
Also changing the Low speed needle will not help this. The engine actually comes with the longer LSN installed and it works great and most actually prefer it than the Short optional one.
You prob know this but I would just double check for air leaks, tank issues, swap out the glow plug etc...
Also for clutches out of the options you listed I would go with the Werks with Alum shoes or a 3 shoe alum setup. In truggy wit the carbon shoes especially with the .23 they heat up and the feel will change and get sluggish after a few minutes of running. But this is just my preference. Aluminum shoes feel more consistant.
#9845
It is a pretty old tank in the SC8(i.e. RC8 tank, once known to have occasional issues), but I just broke in a P5 too, which tuned like a dream..
Plug maybe..
Plug maybe..
#9846
Where are your needle settings?
#9847
Alpha Lutz 2107 Pipe is now available.
#9851
Engine dump problem?
I have an engine (z852) stored for 6 months, I want to try it on an old buggy (hyper9) I do not use for quite some time (just for fun), I had some problems with the carburation and ignition. you think that the engine dump is making troubles on carburation?
Currently turns on the first time, it works perfectly, but it's pretty hard to turn it on after roll over or fuel runs out.
The last time I use it, was on MBX6 (6 months ago) and it worked flawlessly
Thanks for your help.
My current race config is MBX7+Dragon(6.5mm)+2090(7mm)
PS. Sorry for my english.
#9852
shims alpa dragon
Can anyone explain how many washers should I use in my dragon with warm and dry weather to 450m (1400ft) above sea level.
Setup:
Venturi / Carb Restrictor: 6mm
Fuel: 25%
Plug: OS P3 Turbo
Shims: 2x2 0.2m 1x0.1mm (stock)
Gearing: Stock bmx7
Clutch: 3x plastic shoes, springs 1mm
Flywheel: alpha
Track: grip medium / low
Tyres: aka iBeam
Setup:
Fuel: 25%
Plug: OS P3 Turbo
Gearing: Stock bmx7
Flywheel: alpha
Tyres: aka iBeam
#9853
RCMania- PM me your addy. I have a few I could offer up, I only ask that you cover your preferrence for S/H. Due to work though, I won't be able to send out until Saturday.
P-Word - Check your PM. Was kinda cool having an all Alpha Plus AMain, wouldn't ya say? :P LOL.
So I havn't really read much lately...what does the new pipset offer over the 0801? Thx
#9854
#9855
hope this answers your question, i am not sure if many others have had time to try theirs because it was released last week here in the states.
