AB Mods Racing Engines
#481
#490
#491
Adam:
What header/pipe do you get the most power out of for your drag modified TZ-18 engines? Also, what are your thoughts about that particular engine for drag racing to 150 ft, and what kind of power are you getting out of it in drag modified trim? Thanks.
#492
I'm about a gallon and just short of a quart into this engine with the 086 pipe. I've tuned it to about 1 -1/4 turns out on the HSN. Haven't touched the LSN yet because she takes off without bogging and almost no hesitation.
However, I am dealing with the high idle that won't idle down until after about 60 seconds. The engine has never seen over 250-255F and it's driving me nuts.. Any tips on what I can do to calm the idle sooner. This is always after a wide open run.
The wide open runs aren't too long because I'm still taking it a bit easy on it until the nuts drop..
#493
#494
#495
Adam this engine is just straight killer and with a 13:30 run time. The power is instantanious and awesome. I used to run my os 25 mod from last year paired with the 086 but the OS 2060 is the match for this engine. I do not know what you have done but this thing is insane! Your R&D on this engine is top of the line.
2Likes
