Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
The New Werks B5 .21 Racing Engine >
Like Tree63Likes
Old 10-03-2011 | 02:23 PM
  #7711
The carb set screw is the one right below the idle screw right. The carb will not come out its crazy!
seabass34 is offline
Old 10-03-2011 | 03:12 PM
  #7712
No offense but it sounds like you are about to do way more damage than you are good. Your two stage idle is simply a result of an incorrect needle setting, more than likely high speed. Your issues removing the carburetor (which you do not need to do to get the bearings out) I'm at a loss about unless you just removed the pinch bolt and left the actual pinch bolt assembly in. The bottom line though is you are replacing the bearings to get rid of some forward/backwards play in your crankshaft which is completely normal and always there. Any time that you assemble a flywheel on an engine you should pull the crank forward and slide the collet down snug to the front bearing which takes up all of the play. So..... in essence you are fixing something that does not need fixing. My concern though is if you are running into issues just taking your carburetor off, what is going to go on when you pull try to pull the engine apart lol? Best bet, just leave it alone and contact me to work through the two stage idle if it is a problem.
Werks is offline
Old 10-03-2011 | 03:30 PM
  #7713
haha. I got it off man those carbs are in there tight compared to the hpi engine I took apart, but thats a good thing. The flywheel nut was loose I think thats what the problem was. Thanks for the info
Old 10-03-2011 | 03:45 PM
  #7714
blktransam's Avatar
when/if you need to take the carb off simply "losen" the pinch bolt a couple turns and then use the allen wrench and "push" the pinch bolt screw which should then let teh crb come loose a couple twist left and right and whalla the carb will come right ouyt eazy peazy also as ron said 2 stage idle is just a off balance needle setting bro no need to go camando on the engine just yet
blktransam is offline
Old 10-03-2011 | 03:50 PM
  #7715
haha. alright thanks guys
Old 10-04-2011 | 03:04 PM
  #7716
alexrckid's Avatar
HPI/WERKS.....two completely different leagues..........HPI= bash.....WERKS= race...............................
alexrckid is offline
Old 10-04-2011 | 04:50 PM
  #7717
blktransam's Avatar
hmm last time I knew lots of people "raced" "hpi" blitz....now if yhou are talking only engines then okay I will let it slide
Old 10-04-2011 | 05:51 PM
  #7718
Default Big Thanks to Ron
Hi Ron a big thanks for sorting out my issues gear turned up last week, I have not had a chance to try it out yet been waiting for a new Losi truggy kit to turn up its been on order since July!
might have to spend some $$ and rebuild my old losi, which I was trying to avoid as I hoped the new one would have turned up by now, but I am real keen to get this motor hummin.
Cheers for the great service
sbv20j is offline
Old 10-04-2011 | 08:50 PM
  #7719
Integra's Avatar
where the heck do you have the kit on order from ? Are you talking the new TLR kits ?
Integra is offline
Old 10-04-2011 | 09:02 PM
  #7720
Default Sydney
I started off tying to get a LOSA0805 race roller, but was told they were discontinued so they swapped the order to the TLR Kit.
Its one of the main hobby shops in sydney, not really there fault they cant get hold of the kit from omp the Australian Losi importer, I have also spoken to omp a few times, now I am all but ready to give up and look at other brands
sbv20j is offline
Old 10-05-2011 | 04:35 PM
  #7721
PETE THE GREEK's Avatar
Ron,
I am so disappointed in the B5 engine. No problems, in break-in and not even a burp in over 5 gallons of fuel. How do you make money when you make a superior product like that?
Thank you and keep up the good work!
P.S. I can't wait to break in my new one that I have for backup.
PETE THE GREEK is offline
Old 10-05-2011 | 04:55 PM
  #7722
Limywidget's Avatar
Originally Posted by PETE THE GREEK
Ron,
Some people just want problems.......
Limywidget is offline
Old 10-08-2011 | 05:30 PM
  #7723
alexrckid's Avatar
was talkin engines on this "engine" forum.........i do know that the blitz is an awsome ELECTRIC race sc..........even though i dont race sc's......but, they do look like plenty of fun...............i'm nitro all the way.
Old 10-08-2011 | 08:47 PM
  #7724
blktransam's Avatar
well u didnt say engines u said brand names...because on rctech everyone totally keeps the threads on track and all
Old 10-15-2011 | 05:59 PM
  #7725
Pingers's Avatar
Do you guys know which head/heat sink is compatible with the B5 - I can't seem to find them in stock anymore, looking to replace one.
Pingers is offline
