The New Werks B5 .21 Racing Engine
#7742
#7743
Initially, I thought it was slightly starved for fuel, but when I richen the lsn, the truck has much less snap out of the corners.
The top end is good, and the temps are around 225-245.
#7744
It doesn't always come to a strong consisten idle. I set the idle stop as recommended, and I just tune the low end needle to try to get a consistent idle. When I have the lsn where I want it, the engine revs fluctuate.
#7745
#7747
I'll keep you updated. Thanks for the great support!
#7748
Hey quick question as I am interested in a B5 - I thought it was a buggy engine but see a heap of posts here referring to it in truggies?
Has it got too much bottom end for a buggy?
I race a very short track (max straight about 90ft) and am a poor driver so need the punch out of my poorly negotiated corners
so I want a bottom end oriented motor but not one with what most people consider too much bottom for a buggy
#7749
so I want a bottom end oriented motor but not one with what most people consider too much bottom for a buggyA B5 is not too much for a buggy.
#7750
Can someone tell me if the b5 pro parts like crank n sleeve rod is interchangable with say the b5 b6 b6 pro n b2? Basically I'm just wondering if I can change these parts out if something were to happen to the original parts inside. Thanks.
#7751
Most of the parts are interchangeable.
#7753
my b2 piston is diff. then the b2....
as far as I know u can swap everything out between the b5 and b6 but I could be totaly off as I have never needed to swap anything over between the 2
but Ron will chime in on the do's and dont's...
I know carbs,cranks,back plates buttons, heads,rods....all interchange but dont know about the p/s and crank case..
hope this helps
but Ron will chime in on the do's and dont's...I know carbs,cranks,back plates buttons, heads,rods....all interchange but dont know about the p/s and crank case..
hope this helps
#7755
big difference in the p/s(of course) btwn the B5/B6..
B5..
http://www.amainhobbies.com/product_...ton-Sleeve-Set
b6..but, the B6'll work in a B5 block.....just wont perform the same as the B5 p/s..
...rest of the compatability answers...
http://www.amainhobbies.com/index.ph...s-Racing-21-B5
B5..
63Likes
