Sleeve Removal Tool?
#31
Ok ive tried a plastic piece and a zip tie with no luck. This is on a go .21. Next im going to try is to heat it up?? Any advice?
#32
When I have a sleeve that's stuck I shoot some wd40 In there and it slides right out. Shoot some up through the backplate to get it around the outside of the sleeve. It should loosen it right up.
#33
I had an engine where the sleeve was really tight. Zip tie didn't work but my manual actually recommended nudging it out from the inside with the back end of a pen. I used a bic. They are soft nylon and won't scratch anything.
#36
#37
I cant get it to even budge. Ive tried plastic, zip tie, pushing out from bottom, the damn thing wont move. I guess try heat?
#39
#42
#45
