-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   EB Mods JS Engine (https://www.rctech.net/forum/offroad-nitro-engine-forum/316041-eb-mods-javascript-engine.html)
Tony Newland 05-05-2011 11:17 PM
be careful running P3's... you run a risk of breaking the element and sending it through the engine if you run out of fuel, I would stick with P4's.
noddy2 05-06-2011 02:12 AM
p3 glow-plugs
thanks Tony, ile stick with the p4s for JS , and use the p3s in my OS 21 XZB.
http://www.rctech.net/forum/classic_...milies/nod.gif
anyone know why i cant get smiles ?
noddy2 05-10-2011 07:26 PM
Reckwards 2041 pipe/OSp4 plug
Originally Posted by Michael#81 (Post 9066166)
That's good stuff Noddy2.
I have tried almost all the pipes and glow plugs on that list you made.
My favorites are a OS P4 Plug with a Reckward 2041 pipe.
As far as tuning it is going to vary by fuel, clutch choices, and air density that people are running and the way the weather is on a certain day.
Thanks Michael.---I got the pipe today.Am racing this weekend at Moranbah Qld Aus. cant wait to try,it's a big layout ,real long main straight,lots of short straights,and hi-speed corners,Hee-Harr.:lol::lol::lol:
khaliffen 05-11-2011 12:27 AM
+1. I run the same setup and like it
Tony Newland 05-12-2011 07:20 AM
moved
C Gil 05-25-2011 10:11 AM
So where does this leave me?
Ed,
With all the recent changes with the JS engine line over the last month, I wonder where this leaves me. I have been waiting patiently for some news, while your were trying to locate an engine from a dealer and have not heard a word. Will I ever receive a replacement engine from you?
bcarter007 05-25-2011 06:38 PM
Originally Posted by C Gil (Post 9163845)
Ed,
i have called, emailed, pm'd, even message on facebook with no response
from him.......keep trying but i doubt ull ever here anything
EBMods 05-26-2011 04:25 AM
Originally Posted by C Gil (Post 9026914)
I feel as if I am getting the run-a-round because I was told by Joe that he had my engine 3 months ago which I never received. I would like some answers as to why I have not received my replacement engine yet.
Hello Chris, I really don't know what to say.
I replaced your engine, that's why you were told by JOE ALESSI over 3 months ago that he had your replacement engine. Joe then sold your engine not telling me or you, nor did Joe pay me for that engine. So now I'm stuck in the middle.
EBMods 05-26-2011 04:28 AM
Bryce,,
I've responded to your emails,, not sure why you didn't get them? Did you call 1-800-678-1037, I talk to people everyday when they call.
blktransam 05-26-2011 05:35 AM
no matter what happened, JOE worked for YOU so you are liable for his actions good or bad give the man a engine good god!
EBMods 05-26-2011 06:55 AM
Chris, here is the email for the factory [email protected] I'm sure they will send you a replacement just as they did for Tony Newland when his engine blew the clip out with 3.5 gallons on it, yours had less than a gallon.
Ryan if I had an engine I would send him another one licky split.... I think Joe should be held liable for his actions as well don't you?
The factory owes me money for all the engines I returned to them, so far I have replaced close to $20,000 out of my pocket on factory defective engines.
blktransam 05-26-2011 08:11 AM
sure Joe should be held liable 100% but you being the distributer and team owner for the eb mods team should take care of your customers good or bad it sucks but thats is just the way it is.
khaliffen 06-30-2011 02:19 PM
Has anyone tried other carburetors? The standard on both my engines often gets stuck and doesn't move freely. I tried cleaning them both several times
taminhchau1983 07-08-2011 01:00 AM
i'm locate in Vietnam use this engine with JP1 pipe
this is good enigne i'm using the second one(the first one was damaged when sand come inside the engine because of poor air filter) and seem to be it will still be my next choise
after shipped to Vietnam it cost about 270$ for the stock one:mad:
EBMods 07-08-2011 05:29 AM
Hello Khaliffen, please check your end points to verify the slide is not over-traveling past the carburetor body opening. You don't want the slide to travel past this point at wide open throttle. If the slide over travels it will shake inside the carburetor body and bind. If this doesn't solve your problem please let me know.
EBMods 07-08-2011 05:30 AM
sorry double post
khaliffen 07-11-2011 01:56 AM
Thank you for the reply.
I have checked my end points several times and the slide does not over travel, nor did it on my old JS engine, where I had the same problem. So unfortunately your proposal does not solve my problem
Sprinkler 07-11-2011 05:53 AM
I have 3 JS Racing engines for sale if anyone is interested.
JS Racing 23 Race Prep Hellfire engine: New in the box sealed in plastic $ 175
JS Racing 21 Engine new in box: $170 w/ Dynamite 086 pipe
$300 for both 21 engines and 2 pipe combos.
EBMods 07-11-2011 07:00 AM
Your slide may have a burr on the idle screw groove. You will need to remove the slide and check for burrs. Check the inside of the carburetor body as well. If this isn't the problem then maybe contact the factory direct at:
[email protected]
If this is the problem it usally happens when adjusting the idle screw in the clockwise direction, the screw hits the slide which has spring tension from the throttle arm. It's good practice to always open the throttle when adjusting the idle screw.
When you are inspecting the slide also look at the inside carburetor body to see if the slide is being pulled straight. The inside surface will have wear marks from the slide which should be centered.
EBMods 07-11-2011 08:00 AM
Ryan just an update, Chris received his replacement engine.
BIG thanks goes out to Aaron Pucci :)
blktransam 07-11-2011 09:43 AM
good deal :nod:
taminhchau1983 07-12-2011 11:41 PM
Good deal, i'm wish i was in US :sweat:
Nightjus 07-14-2011 02:07 PM
Ed, is there away to get in contact with you. Ive called the shop and its not working??
Justin Williams
338lapua09 07-15-2011 10:53 AM
Did you try this new number 1-800-678-1037 or [email protected]
minigee 07-15-2011 10:53 AM
anyone have tuning settings for the .23 at 6000ft above sea level and dry climate? Runnin the .23 Hellfire Race Prep, Had it dialed in once then something happened and now it wont run for more than 5 secs. Just looking for a base carb setup at 6000ft asl. Thanks
Bruce53 07-16-2011 05:26 AM
PM sent on JS Engine and pipe , do you still have them for sale ?
EBMods 07-16-2011 07:19 AM
Please check the piston skirt isn't broke on the exhaust port side. On some engines at TDC the piston skirt travels past the bottom of the port and will catch on the down-stroke and break.
See link below:
http://ebmods.com/light.htm
Sorry Bruce no engines or pipes in-stock. Try Absolute Hobbyz or A Main Hobbies.
slow supra 07-16-2011 11:31 AM
New EB engine?
Hi Ed, do you have an ETA as to when your new engine will be for sale? Thanks, Jim
EBMods 07-16-2011 11:54 AM
ETA around Christmas / New Year we should have production started on the new .21 engine. Team Drivers and Hobby Shops will have samples to test in Mid-October. This engine will be completly made in the USA, with some of the parts machined in-house at EBMods and other parts out sourced to machine shops.
As we get closer to testing I will have updates and more info about the engine.
EBMods 07-16-2011 12:03 PM
Oh and I have to say I'm VERY excited about this,,, I wish we could speed the process up but small steps first, with lots of testing. It's an amazing feeling everytime we finish a part!!!!!!
Bruce53 07-16-2011 12:20 PM
hey Ed , send one my way !!!!!!!!!!!!!!!
jbright33 07-16-2011 06:41 PM
cant wait for the new motor to test. glade to see you getting set up good edd.
minigee 07-17-2011 03:34 PM
See link below:
Sweet ill Check it out and let you know, thanks for the reply
JoeC 07-20-2011 05:00 PM
I have 2 questions.
1. Is the 9901 Nova pipe comparable to the 2041 in performance and mpg?
2. On the race prep JS do I need to run more break-in tanks through it or is it pretty much ready for race tune right away?
oilguy 08-26-2011 03:38 AM
os vzb carb is absolutely amazing on the js motors!! best friend is using a vzb speed carb of mine in his full mod hellfire .23 and its dialed!!
Dklst 08-26-2011 04:01 AM
:D:nod::D
mikeb8om8 09-25-2011 09:31 PM
My JS .21 is up on the for sale section. Broke in motor and ran 2 tanks. Only $95 for a quick sale. 7.5 venturi. It rips! Only selling because it just bought two os speeds on a hookup. Ebmods make awesome motors!
Matt Farris 09-26-2011 10:09 AM
http://www.rctech.net/forum/r-c-item...prep-s-x3.html
Somebody buy my engines please....:(
oilguy 09-28-2011 08:30 AM
ebmod can dial in horrible motors like js for example and also can make a good engine into an outstanding engine like ninjas...ive had my hands in 4 js of 2 different friends of mine and of the 4, the only one even decent was the full mod hellfire..its a great engine after I threw the p.o.s. carb away and installed a os 21j..the others were all race preps and are total walmart garbage! look into the exhaust port and look rite underneath the piston skirt, etc...but getting ed to return a simple, short email. takes a month per message and forget about phones....sucks cuz the man is very smart and talented and wish we could do more business together but communcation is the key...neal at clockworks knows about communication and the importance of customers from what im finding out..
oilguy 09-28-2011 08:32 AM
Justin Williams
lol...wish ya luck man!! im learning quickly its not even worth the trip from the couch to get ur cell and try...
