EB Mods JS Engine
Old 04-21-2010 | 10:16 AM
  #571
If its running on at the end of the straightaway its too lean on the top. fatten the top 1 hr at a time till it stops running on, then start leaning the bottom till the idle is strong and steady. idle should not be adjusted more then 1/8 of a turn in either direction from box setting for the perfect tune.
One more question, do you know the out of box setting for the idle? I may have moved it too much already.
Thanks again!
Big Daddy05 is offline
Old 04-21-2010 | 10:19 AM
  #572
jpalessi's Avatar
Thanks again!
pull the stack out , then while pushing the slide closed with your finger, back the idle screw out till its JUST closed (even work it in and out to get it perfect) then go back in 1- 1/4 turns.
jpalessi is offline
Old 04-21-2010 | 11:02 AM
  #573
Thank you Joe! You are always very helpful, and that is why I will keep buying Lucky 7 and EB mods products
Old 04-21-2010 | 11:14 AM
  #574
jpalessi's Avatar
No problem! thats why im here!
jpalessi is offline
Old 04-21-2010 | 11:19 AM
  #575
Maximo's Avatar
Lucky 7 Rocks !
Maximo is offline
Old 04-21-2010 | 11:31 AM
  #576
jpalessi's Avatar
Originally Posted by Maximo
Lucky 7 Rocks !
thanks Neil!
jpalessi is offline
Old 04-21-2010 | 11:48 AM
  #577
Shoaf85's Avatar
Decided to throw a Full Mod in my Truggy for some testing on my practice track. This engine is ripping it up for sure. I have a 50' triple on the front straight and my truck is taking it out as easy as my E buggy! Awesome power from this mill and still over 10 min pits while driving very hard!
Shoaf85 is offline
Old 04-21-2010 | 03:50 PM
  #578
pballer2777's Avatar
so i'm thinking of getting 2 of these motors. one for buggy and one for truggy. can someone tell me the performance difference between each one and which motor i'm better off putting in both buggy and truggy. i normally race at 2 different tracks one is dusty hard packed track and the other is clay. both cars r losi 8ights 2.0.thank you for any info
pballer2777 is offline
Old 04-21-2010 | 03:59 PM
  #579
jpalessi's Avatar
I would go with whichever your pocket tells you too. I run the race prepped in my 6T and absolutely love it! I couldn't be any happier to be honest, getting 12 mins to a tank and the power is sick.
The full mod will spool up a bit faster and have a lil more upper RPM. The FM also comes with a TKO ceramic rear bearing.
Both would be fine in either buggy or truggy, as you can tune to suit with pipes.
jpalessi is offline
Old 04-21-2010 | 04:20 PM
  #580
JP IM COMING FOR YA NEXT WEEK MR.BDAY
icemandolmite is offline
Old 04-21-2010 | 04:25 PM
  #581
jpalessi's Avatar
i'll be waiting (literally)
jpalessi is offline
Old 04-21-2010 | 06:36 PM
  #582
vince7870's Avatar
Lucky 7 Rocks !
"hot rocks!"
vince7870 is offline
Old 04-21-2010 | 06:37 PM
  #583
vince7870's Avatar
I cant wait to get a dose of the massachussetts maruaders!
Old 04-21-2010 | 06:53 PM
  #584
THE YO GABBA GABBA FRONT MAN WILL BE IN DA HOUSE
PLEASE NO AUTOGRAPHS !lol
Old 04-21-2010 | 07:06 PM
  #585
jpalessi's Avatar
Originally Posted by vince7870
"hot rocks!"
jpalessi is offline
