EB Mods JS Engine
#256
Hello,
I am almost for sure getting this motor but because of how new it is I am still a little unsure. From the sounds of it so far it seems like for the money there is nothing that touches it. Only things that worry me is how long this motor will last. So I was wondering how many gallons has people put on there motors how does the wear of the motor seem to be. Does it seem to be able to last as long the V-Specs, Nova +4, etc with normal engine maintenance of coarse?
Thanks for any reply's.
Shawn
Shawn
#258
here is my buddies js engine running in his losi 2.0t (single2372)
i was driving his truck in the vid lol.
anyways, even with the 086 pipe this motor is very mellow on the bottom end. its also VERY smooth!
i am running one of singles eb mods go tech in my truggy right now with a go tech 0801 pipe and the thing is a rocket out of the hole.
but here is a video (still working on the tune, its still needs some more fuel to be perfect.)
http://s230.photobucket.com/albums/e...=rcpics256.flv
#259
Thinking of getting myself a new engine for my truggy... Im stuck between the ninja and Js....
What are the differences you guys have noticed between the 2 engines?? I know the ninja is OS quality, can the js be compared to the ninja as far as quality goes, or will I need to perform engine rebuild sooner?? What power differences are noticed, and how is the consuption between the two.
I currently run a picco p7-evo3, and it has great power, and I manage to get about 11-11,5 min runtime..... Will the upgrade be a big difference to the picco?
#260
#262
Would you happen to know if Ed did a dyno on the 2013?? Thanks.
#263
id stick with the 086 then. try experimenting with the carb inserts. even with the #8 in you should definitly get over 10 mins in truggy as i did 8 mins today in my buggy with over1/4 tank left with the 7.5 insert. but this was on a short track but truggy should be able to get 11-12 mins
I do own a Ninja jx21 and the two motors don’t even compare with each other. Both have around same run times but the JS has way more bottom end ready power, temped out at 190-220.
I will be ordering another JS
Ninja jx21 now for sell.
#265
#268
JuD,
No dyno testing with the 2013, but a couple team guys have reported it runs good! tons of bottom, not as much top, good run times but not as good, sounds awesome! typical 2013 characteristics. The JS is not so pipe sensitive so try what ya got!
#269
See you there Hambone. And Joe thanks alot!! I will have my 2013 at practice. I will put the EB Mods pipe on after a few runs.
#270
I know for a fact how well the 086 pipes works since i ran my buggy with a 9886 nova pipe. It's a killer. Very curious to see how much better the RE10 losi will be. Dyno shows it to be alot better on top, mostly equal everywhere else.
