Like Tree1Likes
Sirio engines thread
Old 02-04-2006 | 07:02 PM
  #1126
AndyT ©'s Avatar
Originally Posted by Ivan Dickson
I like that, what is $ tag on the new sirio engine & were can you buy one?
They go for about $245US on RC-Mushroom, or you could go for a Murnan modified one
AndyT © is offline
Old 02-04-2006 | 08:24 PM
  #1127
Racing4Evo's Avatar
I was thinking the same thing about the STI logo. At first I thought it was mere coincidence but then the Subaru STI logo is exactly the same design.
Racing4Evo is offline
Old 02-05-2006 | 01:17 AM
  #1128
MCRUZ's Avatar
Originally Posted by Racing4Evo
Kyosho USA will be the US distributor now. I think they are getting motors next week.
R U Sure??
MCRUZ is offline
Old 02-05-2006 | 08:08 PM
  #1129
wad's Avatar
wad
Yeah, I'm wondering about that too
By the way, from where did you get that picture?
wad is offline
Old 02-06-2006 | 12:53 PM
  #1130
Racing4Evo's Avatar
Originally Posted by MCRUZ
R U Sure??
Okay I'm mistaken. It's Kyosho AMERICA.
  #1131
Racing4Evo's Avatar
The website is on the picture watermark.
Old 02-06-2006 | 01:22 PM
  #1132
T. Thomas's Avatar
After 7 gallons on my first Sirio Kanai 1, it finally gave out. Only regret about it is that it happened during the A main of the 2006 Nitro Explosion in Dallas Texas at Speed Racers Hobby. Do have to say, till it went it was running only at 230 and screaming.
Due to bad picture and a better one take and posted below, I removed this image.
Last edited by T. Thomas; 02-07-2006 at 06:02 AM. Reason: Due to bad picture and a better one take and posted below, I removed this image.
T. Thomas is offline
Old 02-06-2006 | 04:16 PM
  #1133
jeffreylin's Avatar
Peter check your email!
jeffreylin is offline
Old 02-06-2006 | 09:44 PM
  #1134
Slo-MTX4's Avatar
Dude i have never seen a conrod rod or piston that colour. What oil are you using and what % oil?
Slo-MTX4 is offline
Old 02-06-2006 | 10:08 PM
  #1135
T. Thomas's Avatar
The conrod is actually has a goldish color, it actually wipes off, the light I used is bad where I took the picture, that is why it looks spotted(looking straight on it only has a slight gold tint). For the piston and the dark area, the piston is slightly burnt only at the exhaust port area of the piston from the original sirio pipe I had with the plastic coupling piece that leaked and cause cool air to hit the piston while at TDC during the run. The fuel I run has 8% oil in it, not sure which oil is used but it is very good quality in my opinion.
Keep in mind, 7 gallons out of a motor while I rarely used after run oil, right after breaking it in it reached 300 twice due to lack of experience tuning nitro engines, and I have only went through I think a total of 5 plugs in it.
Old 02-06-2006 | 10:58 PM
  #1136
Slo-MTX4's Avatar
I suppose after i convert it from gallons back to litres then yes it is a fair bit. Looks almost black in the pics.
Slo-MTX4 is offline
Old 02-07-2006 | 05:47 AM
  #1137
T. Thomas's Avatar
yea, 7 gallons = 26.5 liters. The picture doesn't really show the true color. The picture I took of it with good light looked as if was light mirrored back at the camera. Here is a more accurate photo of how it looks, took me a while to get the light right.
Old 02-08-2006 | 12:32 AM
  #1138
ChApS's Avatar
Any specs on the new sirio.?
ChApS is offline
Old 03-03-2006 | 09:52 PM
  #1139
need some help from you guys. About a year ago I bought a Sirio Kani EVO 2 motor .21 I havent found much info on it. I was looking for breakin precedures and needle settings, glow plug. Using non turbo head button. Is it worth switching to the turbo style plugs? What Fuel would you recommend? I really like White lightening. BUT I think 8% oil is not enough. More like 12%?I live on the central coast of Cali
I know this is asking alot but I greatly appreciate it! Phil
www.fastlapslo.com
tunnelhead is offline
Old 03-06-2006 | 04:07 AM
  #1140
Default Nova Carb on Evo 3
Have any of you guys tried using a Novarossi Carb on a Sirio Evo 3? Im having a few problems trying to get the Sirio Carb to fit and function cerrectly in my MTX4. It's a very tight fit. I've had to dremel a little from the carby under the midrange needle so not to touch the brake disc and also, the slide hits either the top deck or the fuel tank when the throttle is at around 3/4 open. Also, the rubber boot on the slide gets caught on the topdeck when i open the throttle
Rody is offline
