Like Tree1Likes
Sirio engines thread
Old 07-03-2009 | 03:42 AM
  #2626
GREGORY!'s Avatar
Originally Posted by blown sv
crank shaft
how can be sure about that?
it isn't available yet.
btw how many minutes you make with your xxx in one tank?
GREGORY! is offline
Old 07-03-2009 | 09:23 PM
  #2627
Seisick's Avatar
where can i get a conrod for the 12 evo 4 sti in the us?
Seisick is offline
Old 07-04-2009 | 08:39 AM
  #2628
afm's Avatar
afm
pal motor de martello??....no hay en ningun lado...hay que buscar en Europa
afm
afm is offline
Old 07-04-2009 | 07:54 PM
  #2629
keavze's Avatar
anyone knows the bearing sizes for the 12evo 4STI?
keavze is offline
Old 07-04-2009 | 07:59 PM
  #2630
thisguy2849's Avatar
Thumbs up
Team epic has .12 xxx in stock as well as the .21 on-road motors right now
thisguy2849 is offline
Old 07-05-2009 | 01:20 AM
  #2631
blown sv's Avatar
i was told second hand from a very good source
and it depends on the size of the track , if its small and tight you will get better run time, on my home track i get around 4.40 as its a very large fast track
blown sv is offline
Old 07-06-2009 | 02:42 AM
  #2632
kickass's Avatar
Chad
Ill give you some of my left over fuel, I was doing 6 min stops at Winterchamps the other night. And I was left with 1/3 of a tank after qualies at moorebank the next day.
kickass is offline
Old 07-06-2009 | 03:02 PM
  #2633
blown sv's Avatar
, na dont need it now , its run in a bit more and makes run time
blown sv is offline
Old 07-09-2009 | 11:24 PM
  #2634
where to get the new version of sirio xxx .12? thanks in advance!
silverM3 is offline
Old 07-18-2009 | 03:07 AM
  #2635
Hi guys
Where can I find the .12 sirio xxx conrod?
mydo84 is offline
Old 07-18-2009 | 05:16 PM
  #2636
Does anybody no where to find the XXX manual?
r3nos is offline
Old 07-19-2009 | 02:48 AM
  #2637
blown sv's Avatar
Originally Posted by mydo84
Hi guys
its the same rod as a evo4 sti , so anywhere you buy sirio motors
blown sv is offline
Old 07-20-2009 | 09:03 PM
  #2638
tenderfoot57's Avatar
Is this the same con rod that is in the s12 t3i sti or has the rod changed since then.
tenderfoot57 is offline
Old 07-20-2009 | 09:05 PM
  #2639
If you need parts or serio engines go to www.teamepic.com and you can get the,
Old 07-21-2009 | 01:06 AM
  #2640
blown sv's Avatar
it is different to the evo 4 , evo4 had a bigger piston pin then they made the big end more beefy on the evo4sti and the xxx, so yes the rod is different on the evo3's
blown sv is offline
