Like Tree1Likes
Sirio engines thread
Old 02-16-2004 | 02:59 PM
  #181
afm's Avatar
afm
Originally posted by rc-racer15
$300 are you joking me?!?!?!? man i payed $120 for my reqular sirio, which is cost.
R1ceboy is right, We are talking about a whole new ball game with the Sirio "evo2". They are factory mildly moded engines with performance at par with the newest generation of Nova based engines, so price is at their level, no kidding, these are serious powerfull mills.
AFM
afm is offline
Old 02-16-2004 | 05:30 PM
  #182
S-T-R-l-K-E-R's Avatar
Default .12 sirio AAC 5 port
how long should the fuel line be toward my engine? also the length for the return.
thanks in advance
S-T-R-l-K-E-R is offline
Old 02-16-2004 | 07:20 PM
  #183
afm's Avatar
afm
Default Re: .12 sirio AAC 5 port
thanks in advance
Fuel line towards carb should be enough to get to it in a smooth way.
Pressure line should be minimum 10". The longer you do it from there, tends to lean the mid-range, so you have to tune it for your application.
AFM
afm is offline
Old 02-28-2004 | 06:03 AM
  #184
Default Trinity Sirio AF .15
hello all ive recently been looking at engines for my funny car and have stumbled across this onehttp://www2.towerhobbies.com/cgi-bin...5&I=LXDRC0&P=K
this thing any good??
is the a 1st generation/2nd generation thing like the .12s i need to worry about?
any help would be greatly appreciated
TIA
scott
scottericsonon is offline
Old 02-28-2004 | 09:32 AM
  #185
Default Re: Trinity Sirio AF .15
TIA
scott
I bought one and it ran ok.I put a Rossi carb on it and it woke up.Great low end power and top end was great too.
Mark
markallen is offline
Old 02-28-2004 | 07:17 PM
  #186
Darkseid's Avatar
Regional Moderator
Quick question for you guys.
Do you guys usually add a head shim when you run 30% with your Sirio .12 engines? I already know about using the cold plugs, just wondering if adding shims will be neccesary with this engine.
Darkseid is offline
Old 02-29-2004 | 07:57 PM
  #187
Hey people
Any ideas where I can pick up a Sirio .15 with slide carb and sg crank from HK?
au_Nightmare is offline
Old 02-29-2004 | 08:58 PM
  #188
tl2111's Avatar
Originally posted by au_Nightmare
Hey people
Hi Au
which s12 crank do you need? and which slide carby as well? 2 needle or 3 needle??
PM me
tl2111 is offline
Old 02-29-2004 | 09:37 PM
  #189
I am after a crank to replace my broken sirio .12 one, but also trying to source a new engine - .15 slide carb, sg crank if possible
Old 02-29-2004 | 09:54 PM
  #190
tl2111's Avatar
We have the crank. also s15 is use s12 carby as well if you still need one.
tl2111 is offline
Old 03-01-2004 | 07:15 PM
  #191
shiston's Avatar
Default Sirio 12 conrod/wrist pin/clips
Hi,
Where can I buy a new conrod, wrist pin and clips for a Sirio .12 that will post to Australia?
shiston is offline
Old 03-01-2004 | 11:39 PM
  #192
Pacman25's Avatar
Default Re: Sirio 12 conrod/wrist pin/clips
Originally posted by shiston
Hi,
You can get most Siro parts from Max tech Innovations
Pacman25 is offline
Old 03-02-2004 | 01:21 PM
  #193
shiston's Avatar
Cheers! Will drop them an email
shiston is offline
Old 03-02-2004 | 06:34 PM
  #194
Darkseid's Avatar
Regional Moderator
Anybody...
Darkseid is offline
Old 03-02-2004 | 06:54 PM
  #195
kitracer's Avatar
Anybody...
Let me try
Not necessary. I used 30% trinity fuel, std shim and OS #6 & #7 turbo plug. check the plug condition after.
good luck
kitracer is offline
