Sirio engines thread
#196
.12 engine
guys i have a rr-evo and i'm choosing which sirio engine is better to use with my ride. i narrow down the choices to 2 models, the 5 port evo-2 ABC sg crankshaft or the .12 5 port tup-pro AAC. so which is which..........
#199
Originally posted by sup
buboy, i think there is no evo2 5port. ask local distributor, i think they can help you better and give you a good deal on it. the fast guys in our area use a 5port aac.
and will be using it on my 710 instead
#200
Originally posted by kitracer
Let me try
Not necessary. I used 30% trinity fuel, std shim and OS #6 & #7 turbo plug. check the plug condition after.
good luck
Let me try
good luck
Thats pretty much what I had heard in general. 'try it standard first, then check the plug and see.' Just wanted to make sure that no one was doing the shim right off the bat.And what I'm looking for in the plug is to see if the coil is compressed up into the plug correct? That is the sign of detonation I believe.
Thanks again for the answer...
#202
Originally posted by spenzalii
has anyone has any experience with Sirio's .15? I've considered this engine as a great bang for the buck, but can only find a rotary carb version and very little feedback on it
Mark
#203
#206
http://64.70.208.72/speedtechrc/147.html
So would this be a good price on a Sirio Evo 2? My thoughts are that it would be a good engine for a NTc3? How would this compare to like a MT12? That price range is kinda what I am looking to stay. How does Reliablity and Holding a tune compare to the other brands?
Jeff
Jeff
#207
Jeff
Jeff
Holding tune and sustaining temps is very good, no problems in that area. New carb is very good.
Reliability......I would suggest you change conrod inmediately after break-in process. I think that is the weak point......at least it was for me on my Evo2, which by the way was an early production batch from last year's end trimester. I understand that latest production Evo2's have more low end, and hopefully have addressed the issue of premature wearing of conrod......but
Anyway as i said earlier, it is a very powerful engine, which can hold at par with the latest Nova based engines.
Don't forget to get a good pipe for it. Sirio's own works good, also the Yokomo MMielke, which speedtech has, and lastly i'd try the new Rd Logics turbo II.
AFM
#208
Jeff
Jeff
http://www2.towerhobbies.com/cgi-bin...?&I=LXGGL8&P=0
Mark
#209
Originally posted by markallen
Towerhobbies has it cheaper but it's out of stock right now.
Mark
Mark
AFM
1Likes
