Pipe Coating
#32
I can post a pic later to show as an example...but if you're looking for "durability/quality of finish over time" the ceramic header coating is not what you're after. We originally had the headers on our sprintcar done with the chrome-like ceramic coating and after about a month of racing they basically looked "flat/matte" silver.
One advantage to ceramic coating, i suppose, is that you CAN polish it right back out with a polishing compound and a LOT of elbow grease... but if thats the case...why not jsut use a factory polished pipe?
We're running a satin-black cermic coating now on our headers... it doesnt look as fancy but it sure does a better job.
#34
I have used Jet Hot for years on our motorcycles, always worked great. We have only tried "Black" and its a cool product. I wanted to try the Sterling on mine buggy. I will send and Old 2060 to the and have him do it "Sterling". Let ya know.
FYI, not all ceramic coats are equal. We had a local do some pipes for us for free once, and it was JUNK!! Jet Hot is the way to go if you want ceramic.
Brian at PTM, do you see any draw backs to the Jet Hot as far as performance?? You can come bye one day and I will show you the pipes on my chopper if you want to see exactly what it is.
#36
It takes less than a teaspoon of powder to coat something the size of a pipe. It's not a noticeable weight.
I'm going to coat mine soon. I just can't decide between the colors I have. I'm kinda thinking about this sickening florescent pink I have. It would throw people off for sure. That or a candy purple.
#38
Right.
#41
Here is a little tech type data on the product we are looking at using on the inside of the header.
Insulkote provides a superior thermal barrier for internal and external exhaust systems. Performance properties include; heat transfer reduction, shielding as a base coat under topcoat applications, and maximum corrosion protection after being exposed to high temperatures. When used as a base coat, Insulkote greatly extends the performance properties of the topcoats. Formulated for heat transfer, Insulkote increases performance and horsepower by increasing heat scavenging during the exhaust cycle. The satin smooth finish increases exhaust gas velocity while being able to withstand temperatures in excess of 1800° F.
#43
How much how much ?
