Like Tree2Likes
RB Concept Engine Thread..
Old 04-22-2010 | 08:51 AM
  #1186
RoosterXp's Avatar
What pipe have you guys found for best runtime and decent power with a C6T? i also run a JP3 and 30% on in it now and it seems to run decent..
RoosterXp is offline
Old 04-22-2010 | 08:57 AM
  #1187
Chris Peralta's Avatar
Originally Posted by diamondracing
Let me know when Bryan finishes the magic potion and you try it. We will let you be the test subject
I cannot go to Nats this year work is slow and I am on a budget but I do know Bobby Tillman (mugen guy from Az) will be there this weekend to battle with you guys.
see ya
don
Ahh yes I will test it out for sure, I currently run Byrons and I like the fuel but it does leave a lot of build up in the engine. I know when I ran nitrotane (Also made by VP) my engines always looked great when I pulled them apart.
I hope Tillman is checking in with Randy a lot about racing up here this weekend. The race has already been pushed back to Sunday because of weather and with the forecast it could possibly be a lake by Sunday.
Chris Peralta is offline
Old 04-22-2010 | 08:58 AM
  #1188
The best fuel economy I have had was running the 192 header and 2045 pipe. I tried a few of the JP pipes and never had very good luck with them, I think all I ever tried was a JP1 and a JP2 tho.
Old 04-22-2010 | 02:03 PM
  #1189
What the difference between the Sport 10, Junior 9, and the Nova N21R?
MMor101 is offline
Old 04-22-2010 | 07:56 PM
  #1190
aznitronut's Avatar
I will second that about the JP pipes!
aznitronut is offline
Old 04-23-2010 | 08:13 AM
  #1191
The Junior 9 is a 3 port square stroke motor that is Nova based.
Sport 10 is a 3 port motor that is made in Taiwan that is based on the K9/K10
The Nova N21R is very similar to the Junior 9, they have the same bore and stroke and are both 3 port engines with standard plugs. I am pretty sure Nova has a new 3 port out (P3??) that is now a long stroke motor.
Old 04-23-2010 | 10:12 AM
  #1192
diamondracing's Avatar
If those were your choices of what u are going to buy go with the Junior 9.
I personally own one and just broke in and race tuned one for a friend. For the money it is the best engine you can get IMO. Put a 2045 pipe and either a 192mm or 198mm header and you will be
diamondracing is offline
Old 04-26-2010 | 12:54 AM
  #1193
BSC's Avatar
BSC
Any tuning tips for a C6 , running ODO97T
BSC is offline
Old 04-26-2010 | 06:05 AM
  #1194
As long as the engine is fully broken a good race tune usually has the LSN very close to flush with the HSN also very close to flush. Depending on the header and pipe you use the HSN may end up in from flush.
Old 04-26-2010 | 10:21 PM
  #1195
razzie's Avatar
Default Dynamite pipe
Hi All,
Have anyone tried the Dynamite Platinum 053 Midrange Inline exhaust system on the C5 or C6? Hows the performance and mileage? Thanks
razzie is offline
Old 04-27-2010 | 05:55 AM
  #1196
Originally Posted by razzie
Hi All,
It will run pretty good on that pipe but the fuel mileage isn't going to be very good. If you want the best possible fuel economy for that engine you should go with the 2045 pipe. I have heard the Nova 9901 pipe works great too but have not tried it myself.
Old 04-27-2010 | 07:26 PM
  #1197
razzie's Avatar
Hi Chris,
Im using the RB2045 pipe and 192 header now, but the mileage doesnt seem to be that good on a tight and technical track. Im getting 7.5mins only.
razzie is offline
Old 04-27-2010 | 08:04 PM
  #1198
Hi Chris,
I also didn't have good luck with the 2045 pipe but I was running it on the K9.I like the RE10 pipe good power and get about 9:30 to 10:00 min on a tank.With the 2045 my temps went up 20 deg and got less mileage.
xxxntwv is offline
Old 04-27-2010 | 08:44 PM
  #1199
razzie's Avatar
I find that the 2045 doesnt have the punch at low to midrange as well for a very tight track..Any other views on the Dynamite 053..?
razzie is offline
Old 04-27-2010 | 11:15 PM
  #1200
any one know the part number for the head button for the shark or where they are for sale thanks
dan200487 is offline
