Like Tree2Likes
RB Concept Engine Thread..
Old 02-12-2009 | 08:39 AM
  #106
Akhor's Avatar
What's the optimal temp for a RB S3?
Do they run around the same temps (230) as other engines?
Akhor is offline
Old 02-12-2009 | 10:38 AM
  #107
cbaranski's Avatar
I run a C6BB7T with the 2045 pipe and 192 header. Byrons Gen2 30% with a med plug and my RC8T is totally off the hook. With my temps at 190-210.
Chuck
cbaranski is offline
Old 02-12-2009 | 11:14 AM
  #108
Akhor's Avatar
Chuck
Awesome thanks.
I know I have to tune for power, but I like to have a rough estimate of what the engine temp will be.
Akhor is offline
Old 02-12-2009 | 12:09 PM
  #109
Originally Posted by Akhor
I have a RB S3 and was thinking about running it with a JP 3.
Or would a 086 be a better option?
im wondering the same thing as well........... i borrowed an s3 from a friend to run this weekend and all i have that is close for this pipe is a jp3! what should expect from this setup?
crawldad91 is offline
Old 02-12-2009 | 04:36 PM
  #110
cbaranski's Avatar
crawldad91, Akhor,
My experiance with all of my RB engine is that use the RB pipe that they suggest for your engine. Basiclly almost all RB engine will want either a 2020 or the 2045 pipe. The JP-1,2,3,4 pipes made the engine run hot. I had a WS7III that would run 260 to make any kind of power, but was concerned with the temp. I went to the 2045 with a 198 header. Engine had all the same power ans got better fuel milage and would run at 190-215. My C6 was the same way. The 2045 is the best combo with any RB engine in my opinion.
Chuck
Old 02-12-2009 | 05:34 PM
  #111
what about say..... a 2041? i use this on my osspeed
Old 02-12-2009 | 08:21 PM
  #112
cbaranski's Avatar
I dont know, never ran that pipe.
Chuck
Old 02-12-2009 | 09:49 PM
  #113
i might throw it on just to see what it will do
Old 02-13-2009 | 03:08 AM
  #114
cbaranski's Avatar
Cant hurt to try. Never know, might be a sweet combo.
Chuck
Old 02-14-2009 | 11:12 AM
  #115
Default mixture screw o-rings (c6bbt)
can anyone help with installation of new o-rings on the high speed needle? the needle just won't go back in with the new o-rings without destroying them.
avbrando is offline
Old 02-14-2009 | 01:28 PM
  #116
bjr48's Avatar
You're not trying to put them in dry are you? I would think that might tear them. You want them to fit nice and tight so a little lube would probably be necessary to put them in. Turn the needle very slow too and maybe "help" the o-ring in a little with your extra hand by pushing them into the hole? Don't really know what to use to lube them but probably a little spit couldn't hurt them
bjr48 is offline
Old 02-14-2009 | 10:57 PM
  #117
use after run oil to lube o-rings
rkhess is offline
Old 02-17-2009 | 11:13 AM
  #118
PinoyCali's Avatar
Hello guys,
Is this engine C6BBT II L2G ok for st-rr and what kind of pipe you using?
Im to get one next month.
Thanks.
PinoyCali is offline
Old 02-17-2009 | 11:19 AM
  #119
bjr48's Avatar
I was afraid to say that one becuase I thought I recalled reading somewhere that injecting after run oil into the carb by the fuel line would cause the o-ring life to be shorter.
You should always inject after run oil down the air intake or glow plug hole
I guess a little oil one time couldn't hurt much though.
bjr48 is offline
Old 02-17-2009 | 11:45 AM
  #120
Will the carburetor pinch bolt from the "S" series fit on the S3. The S3 pinch bolt does the job. I am just looking at a different option. Thanks!
Shooky is offline
