Like Tree2Likes
RB Concept Engine Thread..
Old 12-31-2009 | 11:01 AM
  #871
Default Thanks
Thanks man no not blowing plugs just wanted to no if it was right. Does the extra .10 make any big diffence in the power or anything i think i may try .40 sat at a local race. Thanks again man great fast post back to me.
Speedyrob is offline
Old 12-31-2009 | 11:17 AM
  #872
Chris Peralta's Avatar
You may notice a little less power and possibly an erratic idle by going up to .40. If it acts funny just go back to the stock shims and you should be set.
Chris Peralta is offline
Old 12-31-2009 | 11:21 AM
  #873
It wouldnt hurt to lose some Power but i do love a crisp idle i test and see how it does Thanks man u been great. Happy new years to you and everyone reading have a safe and fun night
Old 12-31-2009 | 01:55 PM
  #874
aznitronut's Avatar
Originally Posted by Chris Peralta
I will be running it in my buggy, I run the C6USA in truggy because that thing is a monster with a 2020 pipe.
If you race on a short track that 2020 pipe is okay, if it's to much bottom, try the 2045, it will take away the insane bottom, and will be more linear all the way thru.
aznitronut is offline
Old 12-31-2009 | 02:57 PM
  #875
I have ran a 2045 on it a few times but I generally like the extra bottom end for truggy, a lot of that probably has to do with my altitude and loosing so much power up here I need all I can get.
Old 01-01-2010 | 06:13 AM
  #876
JUD's Avatar
JUD
Originally Posted by aaron joy
Jud they are talking about the C6 not the K9. A stock C6 would only come with two shims. If you are unsure how to take a shim out I will do it for you. LOL
Oops!!! Sorry I got lost in the thread!! I know how to take the shim out. They all look the same size(Killer9). I just took one out so I will see how it runs. Thanks Aaron.
JUD is offline
Old 01-01-2010 | 12:43 PM
  #877
gixxerman's Avatar
I have been running a WS7 for the last year and a half, aprox 5-6 gallons. I decided to pull the motor apart for a little PM, and noticed a proportionaly large amount of carbon build-up just on the top of the piston. After some carefull cleaning I also noticed two very small nicks in the top of piston maybe from a coil on the plug. I was wondering what caused the build-up ie. tune, fuel, wrong plugs, and if the nicks in the piston itself would hurt performance or tune. I have been running OD 77t and 97t plugs. The rest of the motor is basically spotless and it ran fine prior to tear down.
gixxerman is offline
Old 01-02-2010 | 08:27 AM
  #878
Nitro-Racer*'s Avatar
hello, i also have a K9 and its giving me trouble at tuning. i am running 25%, should i take a shim out? Thank you
Nitro-Racer* is offline
Old 01-02-2010 | 03:23 PM
  #879
aaron joy's Avatar
The carb is a little touchy to tune. Taking one shim out is not going to magically make it any easier to tune. Did you seal the carb?
Check out this video:
http://vimeo.com/7595905
aaron joy is offline
Old 01-03-2010 | 05:47 AM
  #880
ok problem solved, i have retuned the engine and is now running great. thank you for the tips.
Old 01-03-2010 | 08:22 AM
  #881
aznitronut's Avatar
Yep, I did not notice your location, makes very good sense now, good luck.
Old 01-04-2010 | 07:50 AM
  #882
The build-up on top of the piston is fine, it's a good indicator that you have had plenty of lubrication in the engine as the build-up is from the oil in the fuel burning. Some fuel does it more than others as well. I have noticed with Byrons fuel I get more build-up than I did with Nitrotane. The little nicks in the piston are very likely from a plug that broke apart. Sounds like the engine is working good for you so keep running like you have been.
Old 01-06-2010 | 02:58 PM
  #883
TXRC8racer's Avatar
Anyone know that a Nova .21 Conrod will fit a RB .21 ??? I have been looking for a new conrod in the for sale section and a guy wants to sell me a new conrod for a Nova. Will they work?
Thanks Lance
TXRC8racer is offline
Old 01-06-2010 | 07:48 PM
  #884
gixxerman's Avatar
Thank you!
Old 01-06-2010 | 09:04 PM
  #885
8&stuff's Avatar
Thanks Lance
I tried a nova r7 rod in an s5 a while back and i could get it to go on and in although was super tight so i put the original back in(the original was fine to begin with). But according to what i read they are supposed to be one and the same.
8&stuff is offline
