Like Tree2Likes
RB Concept Engine Thread..
Old 05-28-2014 | 03:21 AM
  #3466
Then again, just watched the videos of the Clockworks V20 and Rally 14. May have to go with a Clocked engine instead. Still want to know what is the Direct Intake though.
A7racer is offline
Old 05-28-2014 | 03:24 AM
  #3467
Where's a video of a Rally 14?... Link?
Herrsavage is offline
Old 05-28-2014 | 05:09 AM
  #3468
joey91473's Avatar
Can't go wrong with the clocked v20. I saw one race this past weekend and it was a screamer. I personally run the clocked V15 and it's a beast. Run it in my truggy..
I see a new video out of a clocked 3 port RB engine. Looks pretty sweet.
joey91473 is offline
Old 05-28-2014 | 05:20 AM
  #3469
Maximo's Avatar
well I didn't post this video as its only a test run in grass..... With the spring rains this was the only dry patch I could find and I was eager to test this engine out........... My track wont open till the weekend, so this is the best I have for now, anyone else who is climate challenged will understand this and not say anything derogatory.!
Anyways this is the Clocked Blastv20/rally X-Treme Speed edition on the RB 2097/41021 manifold............Engine runs excellent, gets very good mileage and is fairly fast and powerful ..In this video the engine is only a tank off the breakin stand and still has a little ways to go before its will produce peak performance....
+ YouTube Video
https://www.youtube.com/watch?v=DQ4rNqvRUZw
The Blast V20 and the RallyX are the same engine, only difference being the insert in the carb and the lettering on the head....The Rally14 is the same as the Fire11, it is a different sleeve then the Rally X and Blast 20......
Maximo is offline
Old 05-28-2014 | 05:21 AM
  #3470
Maximo's Avatar
And here is my torque mod of the same engine model.....
+ YouTube Video
https://www.youtube.com/watch?v=InoXvOBFC9w
Maximo is offline
Old 05-28-2014 | 05:24 AM
  #3471
Maximo's Avatar
Has a keep-off style bearing......they call that the Direct intake as far as I can tell ...
We have been testing a BXRSLSDI5 and so far it has been a good running mill.....Very comparable to a Bonito or Keep-Off 7, but with more low end grunt...
Maximo is offline
Old 05-28-2014 | 07:01 AM
  #3472
So should a 7-port V20 or Rally X be good in a truggy?...
Old 05-28-2014 | 08:27 AM
  #3473
Maximo's Avatar
My Clocked version makes a truggy dance !! ...but I would imagine the stock version is no slouch and would have no issues with truggy ...
Maximo is offline
Old 05-28-2014 | 09:39 AM
  #3474
Thanks Neal for posting the videos and your responses. I didn't know there was an Rally X speed edition and a Rally 14, thought they were the same. New to RB so I only saw the 14 around the net.
A7racer is offline
Old 05-28-2014 | 09:41 AM
  #3475
BillyT.'s Avatar
Stock 19 good in truggy, if you are racer... It's not gonna do wheelies, but it's not losing down the straight either. So the 7 ports should be even better...
BillyT. is offline
Old 06-23-2014 | 03:30 PM
  #3476
JTKI3's Avatar
Just an update...I've been racing my bxr sls3 for about a month now and its been an incredible mill. Unbelievable low end power with plenty on top as well and close to 11 mins of runtime with a 7mm venturi installed. Highly recommend this engine, especially for tight tracks.
JTKI3 is offline
Old 06-26-2014 | 11:12 AM
  #3477
markmad777's Avatar
For those still running the BX and BXR the previous generation RB we have got a better result from changing the to a medium header instead of the long one supplied in the combo kit .It basically adds power everwhere ,perhaps if you battling for traction and then the longer could be easier to ride though.
We should be goiing over to the new SLSDI5 and SLS5 this weekend and will test the make the same swop to see if the result is similar .
markmad777 is offline
Old 07-05-2014 | 03:13 PM
  #3478
DaveG28's Avatar
Hi guys,
My engine is about broken in now, seems very rich at the top still and due to lean a bit, but as soon as I do I find it doesn't drop back to idle very quick, it hangs on for a little while spinning the wheels (on the box)...
..is this normally a sign of a lean top? I really find it hard to believe the top is lean so what else may it be?
DaveG28 is offline
Old 07-05-2014 | 04:31 PM
  #3479
Without hearing/seeing it. I would try pinch the fuel line and see how long it takes to run out of fuel. I believe it should be between 3-5 seconds. It could be rich on bottom and maybe your idle gap is to large. You may need to lower your idle.
Check out this video.
http://vimeo.com/7595905
Chris Reilly is offline
Old 07-05-2014 | 06:57 PM
  #3480
DaveG28's Avatar
Ok, I played and changed the problem. Typical. So here is how it's running..
1st this is how it revs up mid use and comes back down:
https://vimeo.com/100010904
This is what happened after 30 seconds of idle:
https://vimeo.com/100010123
And this is after a 90 second idle...it stalls when throttled:
https://vimeo.com/100010165
Appreciate any help! Am pretty confident the hsn is in the range but on the rich side of it, idle and LSN not so sure! Can any experts help!?
DaveG28 is offline
