Like Tree2Likes
RB Concept Engine Thread..
Old 01-26-2014 | 07:52 AM
  #3346
wingracer's Avatar
A bigger exhaust port means more top end power. Unfortunately when it gets really big, piston stability is reduced and you can get scoring on the piston where it catches on the edge of the top of the exhaust port. The MES design is just a really big exhaust port with a couple bridges in the corners to reduce the chance of piston damage.
On another note, I used to run a high carbon fuel that could actually plug those ports up with carbon build-up after about a gallon. When that happened, power dropped noticeably. Regular tear downs for cleaning kept it running great.
wingracer is offline
Old 01-26-2014 | 07:59 AM
  #3347
wingracer's Avatar
As for 14.5mm cranks, that was mainly done for onroad motors. We were all hogging out the bore so much that crank failures were occasionally happening. Nova went to 14.5mm to beef them up a bit. There really is no performance advantage what so ever to it and in fact, everyone else has stuck with 14mm cranks. The only reason they are finding their way into offroad motors is because everything else Nova makes now uses the 14.5 crank (even Maxpower and the Kangaroo have gone with it now) so it's more cost effective to use off the shelf parts than dust off old cnc programs, case molds and order old bearings.
Old 01-26-2014 | 03:38 PM
  #3348
Question for those that know the original RB S7 or S5, I have one in the pit-box with a broken con-rod. The con-rod looks like this but just to know, in all these years did the part number changed or a improved con-rod is out there? Thanks.
30Tooth is offline
Old 01-27-2014 | 05:36 AM
  #3349
BillyT.'s Avatar
So my V19 lost mech pinch in about 4 tanks...
Idled one, then 2 slow figure 8 tanks(cool at BDC) then slow lap on track, and it was gone... Kinda sketchy. Seems fine though, otherwise. Still pretty rich. About two turns from race tune on low and one on high. Prolly about 10 tanks in so far. Had a rear pinion bearing come apart so I had to stop.
I usually do two idle tanks, 3 figure 8s then start on the track and the pinch is still pretty apparent for the first half gallon at least.
Prolly get a race tune on it later this week. Will report back.
BillyT. is offline
Old 01-27-2014 | 07:42 AM
  #3350
rb still uses the 1122c connecting rod on everything
ncdirtracer is offline
Old 01-27-2014 | 08:44 AM
  #3351
Are you sure? Last I had my one F11 open, the rod had a "10" on it I think..(not %100..) Was wondering what rod I would need for it..
Herrsavage is offline
Old 01-27-2014 | 09:43 AM
  #3352
wingracer's Avatar
Check the size of your crank pin. If it's 5mm, any Nova R rod will work. Older RBs used a smaller pin, like 4.9 I think. Those will need an old RB rod. Roleof knows the exact dimensions, I could be wrong.
Old 01-27-2014 | 05:09 PM
  #3353
my bxr uses a 1122c rod. I have a bunch of rb engines and the exploded diadram of the motor all have 1122c rods. the number stamp on the rod might be diff. but the same 1122c.
Old 01-27-2014 | 05:27 PM
  #3354
wingracer's Avatar
Looking through the old manuals, it looks like they are right, everything uses an 1122 rod of some form or another.
Old 01-28-2014 | 03:11 AM
  #3355
Hello! I am running RB Blast V.9 engine. It is cold -15°C (5°F). Is it ok using O.S. P4 Turbo Glow Plug "Super Hot" ?
ivan b is offline
Old 01-28-2014 | 03:35 AM
  #3356
Thanks all, the crank pin is 4,97mm so I have more options but I have easier access to RB parts
30Tooth is offline
Old 01-31-2014 | 10:34 PM
  #3357
What would this new Rally engine be like in a buggy or truggy? The price is nice...
http://www.amainhobbies.com/product_...ine-Turbo-Plug
http://www.amainhobbies.com/product_...ipe-Turbo-Plug
Old 02-04-2014 | 01:05 PM
  #3358
would like to know this too......anyone?
A7racer is offline
Old 02-04-2014 | 01:09 PM
  #3359
I have a Blast V15 and the rod has some slop in it already. RB replacement rods are too expensive and would like to know which of the Nova rods will fit this? I know I read somewhere to measure the crank pin but I don't have measuring tool and Im hoping someone here knows off hand....any other rod other than a Nova that will fit? Alpha, GO etc? I know the quality is lower on the other brands but I cant see spending the coin for an OEM rod for such a budget engine at this point.
A7racer is offline
Old 02-04-2014 | 03:39 PM
  #3360
I'm going to give my uneducated opinion here, which may well be wrong.. but from my memory, Go and Alpha rods are the same dimensions in terms of hole size and distance between the holes, so should work for RB and Nova engines. However the outer dimension might be larger or smaller so might rub on the case. Now Alpha have two different rods, the regular one and the Lutz one, which are in terms of hole size and distance same, but different externally.
Anyhow, if I were you I'd just get the cheap Go rod, as a gamble, and try it to see if the outer lower edge of it rubs on the case or not, if it doesn't rub, meaning the groove in the case is large enough for it to clear, you're good to "Go".
Eivind E is offline
