Like Tree2Likes
RB Concept Engine Thread..
Old 07-08-2011 | 11:43 AM
  #2221
Clutch set up in truggy is green and gold spring with dynamite max life shoes. Chris, what do you thing of shark9 in truggy?
Big_one is offline
Old 07-08-2011 | 11:50 AM
  #2222
Chris Peralta's Avatar
I have tried the Shark9 in truggy and it just didn't have enough grunt for my liking, but I run at 6,000 feet elevation so I am losing 15-20% of the engines overall power right off the bat. It felt better in truck when the Shark9 had a ceramic bearing but I still I felt I could use a bit more power. It's very possible it will have plenty of power at sea level!!
Chris Peralta is offline
Old 07-09-2011 | 03:40 AM
  #2223
TIX's Avatar
TIX
I wasnt to much a fan of the shark in the truggy. lacked bottom end. on a big open track it was great. it reved harder than the b10
Chris will the 2087 pipe give me any advantage over the 2045 pipe on a C6USA?
TIX is offline
Old 07-09-2011 | 06:29 AM
  #2224
aznitronut's Avatar
Change out your green springs to the silver springs, green is too light for the dynamite shoes, they are really hard shoes, with the gold and silver combo, you should have better snap, than with green and gold.
aznitronut is offline
Old 07-09-2011 | 06:37 AM
  #2225
aznitronut's Avatar
From what Chris had posted in an earleir post, the 2087 is smoother with better fuel mileage, than the 2045. If you have a B10, those are pretty much the same as the C6, if you want more bottom, RB has the 204 header that will give you more bottom.
Old 07-09-2011 | 07:33 AM
  #2226
Any of you RB engine gurus happen to have a spare C6 turbo
head button, that you could let go of for a decent price ?
rageworks is offline
Old 07-09-2011 | 08:34 AM
  #2227
The 2087 is a smoother transition from mid to high but I feel it does make more torque down low than the 2045 makes. I have been running the 2087 on what is basically a C6USA as it's a B10 with a C6USA crank and button. I have been running it in my truggy and it seems to run great and even with a steel flywheel it has plenty of grunt. In the truck I can notice the loss in top speed when compared to the 2045, but it's not too bad.
Old 07-09-2011 | 08:36 AM
  #2228
I am out of town right now, but I am sure I do have one. Send me a PM reminding me to look.
Old 07-09-2011 | 10:53 AM
  #2229
aznitronut's Avatar
Depending on the truggy your using, On losi truggy, Im running a 48 tooth spur gear, on a C6, 2045/192, no complaints.
Old 07-09-2011 | 08:09 PM
  #2230
I too run a Losi truck.... I have tried the 48 and also have a 49 tooth I have tried. With my altitude I really notice the loss in power on the bottom end so I normally end up back with the 50. Plus we are not lucky enough to have a track as big as the nitro pit so it works for me almost everywhere. Next I want to try running this new 2087 pipe with the 204mm header and the 48 tooth spur.
Old 07-10-2011 | 09:04 AM
  #2231
aznitronut's Avatar
Sounds good for you to try the 2087/204, I would think with that combo, it would work well for you in Colorado. We are very lucky to have all the different track we have in Arizona, at least we have 5, just inthe metro Phoenix area, varying in different sizes and layouts, with the Nitro Pit the largest, I really don't change, if any, from track to track, tires, or braking mainly.
Old 07-10-2011 | 08:56 PM
  #2232
camiloro's Avatar
good day, i have a dude.
my old WS9 is dead, y wanted a new RB, i see a killer 10, and X11, this two engien, have more botton end, with my old WS9????
wich one two engine, is more similar to my old ws9
camiloro is offline
Old 07-10-2011 | 09:31 PM
  #2233
The X11 is closer to your WS9. The K10 is more of a sport engine and is not made by Novarossi like the X11 and your WS9.
Old 07-10-2011 | 11:43 PM
  #2234
The x11 is a 3 port,The Fire 11, 7 port is closer to the WS9.
kyosho28 is offline
Old 07-11-2011 | 01:04 AM
  #2235
Really loving the c6 l2g in the buggy now massive power!
Rolled over once or twice and cut so I upped the idle but what a beast it is!
Ginters is offline
