Like Tree2Likes
RB Concept Engine Thread..
Old 09-03-2010 | 09:26 PM
  #1486
aznitronut's Avatar
Originally Posted by hambone
Mine sizzles inside with .3 shims. Just tried that today. I must have an airleak.
Do you know what the shim sizes are? You can spray nitro cleaner or motor spray around the carb, or back plate, pinch bolt, if the engines dies, thats where the air leak is. check back plate seal also.
aznitronut is offline
Old 09-03-2010 | 10:21 PM
  #1487
hambone's Avatar
I had .3mm shim in it, or .012" USA language, lol. I guess i should call Uriah about this one. I'm about ready to slap a standard C6 head button on it if i can't get it straightened out soon. When i broke it in it had .020" shims in it and didn't get any hotter than 235 deg and come to think of it the thing was sizzling inside that day when i cut it off.
hambone is offline
Old 09-03-2010 | 10:29 PM
  #1488
cdc
What %fuel are you using.
cdc is offline
Old 09-03-2010 | 10:31 PM
  #1489
hambone's Avatar
30%
hambone is offline
Old 09-03-2010 | 10:49 PM
  #1490
cdc
The engine or the fuel tank might have an air leak.
cdc is offline
Old 09-03-2010 | 11:05 PM
  #1491
hambone's Avatar
This is the only engine i have with problems. I'm gonna add shims tomorrow and seal the backplate. Never had to seal an engine before. All the o rings look great. This engine has a break-in and 1 day of racing in my friends buggy and hasn't functioned properly since. And come to think abt it that's when i went from .020" shims to .012" shims because somebody else that raced one told me the RB manual said .012"(.3mm) was the proper shimming. OS is so much easier, lol.
hambone is offline
Old 09-03-2010 | 11:11 PM
  #1492
TIX's Avatar
TIX
It sounds like have an air leak
if you dont want it ill be glad to purchase it off you
TIX is offline
Old 09-03-2010 | 11:12 PM
  #1493
tc5 man's Avatar
dont , give up on it i have a rb s5 and im on my second gallon and somehow got it to run and start and run about 235 @.
i run the stock shims because i run 20% ebmods race blead.
its pretty fast.
runs good !
tc5 man is offline
Old 09-03-2010 | 11:17 PM
  #1494
cdc
0.20 shimming is proper shimming for 30% fuel.
cdc is offline
Old 09-04-2010 | 05:49 AM
  #1495
aznitronut's Avatar
Does the engine still have good pinch on the piston and sleeve? If you only have a break in and one day on track, it's not totally broken in yet, get your shims straightened out, and be patient, engines will tend to run hotter till fully broken in.
Old 09-04-2010 | 09:26 AM
  #1496
hambone's Avatar
It's broken in. I took it to the track at least 10 times only to put one my other engines on for racing since the RB wouldn't function properly. I'll get some lucky 7 tomorrow and put shims back in. I keep hearing a OS .25 calling my name! Pain in the ass Italian engines, lol.
hambone is offline
Old 09-04-2010 | 09:35 AM
  #1497
cdc
It should run better with 0.20 shimming.
cdc is offline
Old 09-04-2010 | 11:22 AM
  #1498
hambone's Avatar
Took shimmimg to .020" and ran out back for a bit. Way different engine. Had to readjust carb and it was acting very nice for a change. The true test will be tomorrow at the track. Thanks everybody for the help.
hambone is offline
Old 09-04-2010 | 01:41 PM
  #1499
RCBOY 1's Avatar
ok im new to rb engines just ran across a great deal on one and got it it a c6 with the Rick Brakes Mod on it does anyone know what temps it should run at if so that would be appriciated thanks
RCBOY 1 is offline
Old 09-04-2010 | 01:53 PM
  #1500
cdc
220-260
cdc is offline
