RB Concept Engine Thread..
#1457
#1460
The idle drops after 3-4 seconds. After that it would take off slow, so I leaned the bottom until it would take off when i squeezed the trigger. It was killing plugs before that. The motor has ran the best and longest with mc59 plug. Thats what makes me think its loading up and killing the plug. I have read that if the plug is distorted then its to lean.
#1461
well i had a similar problem but my odonnell plug was brown on the surface and the coils, looked good on the last couple of coils but the top ones did look diffrent, and my would just idle good than it would drop down and load up even though i leaned the low end needle out. did yours flame out too while you were racing ?
but i used, a new plug and it idles great and keeps on running and i could get a tune. im on my secound gallon on my s5
#1462
#1464
#1468
OK I did some testing tonight with the 20% and a Cold Plug and this is what I came up with. I set all the factory setting on the needles. Started the engine and it was really fat. I leaned the hsn about 3 hours total and was producing good smoke and it runs great on the top end. So I started on the LSN, all in all I took 8 hours out of the bottom and put 1 back in the top. The motor runs good on the top and will idle. After a count to 5 the motor will rev up nice and fast. Big puffs of smoke on the bottom at the start and a nice small stream when WOT. Thanks for all the help.
#1469
Yes those two are compatible, the crank is the same the piston sleeve and rod are the same the only difference will be the cooling head, they both might be L2G or the C6 could be an old style head that will cool better.
#1470
2Likes
