REEDY .21 Nitro Engine
Old 11-03-2010 | 04:38 PM
  #1156
Do-Over's Avatar
Originally Posted by shanem121
2039 is what most run in truggy, i ran a 2035 but liked them both
I thought the "39" was the top end/milage pipe. I think the "35" has more grunt to pull a truggy but I do know Sylvain on here runs the "39" and loves it in truggy so maybe I'm wrong....
Do-Over is offline
Old 11-03-2010 | 05:07 PM
  #1157
mgtmadness2007's Avatar
I run a 2035 in my RC8T FT, but our Track has alot of turns and jumps after them.
mgtmadness2007 is offline
Old 11-03-2010 | 09:07 PM
  #1158
AlanHall's Avatar
i was wondering if the 2039 took away to much bottom.
AlanHall is offline
Old 11-04-2010 | 04:15 AM
  #1159
R/C Tech Elite Member
I run my Reedy 121vr with a 2039 in my RC8T. The bottom out very acceptable with the 2039 even in a RC8T
Sylvain is offline
Old 11-05-2010 | 02:26 AM
  #1160
MCR82's Avatar
Can anyone assist me? I am about change front & rear bearings in my Reedy, but am unsure of how to go about it - can any one steer me in the correct direction, I also brought a Ofna bearing puller kit.
Any help?
MCR82 is offline
Old 11-05-2010 | 03:42 AM
  #1161
Reedy 121 VR-ST is online now!!
http://www.teamassociated.com/news/l...n_Nitro_Engine
Old 11-05-2010 | 01:46 PM
  #1162
Any help?
Strip the motor down to just the Block with the bearings in it. Heat it up to about 225F and then pull the bearings. I use this method.
http://www.youtube.com/watch?v=Whpws...eature=related
http://www.youtube.com/watch?v=Q3xIW...eature=related
shanem121 is offline
Old 11-05-2010 | 01:48 PM
  #1163
MCR82's Avatar
thanks
MCR82 is offline
Old 11-05-2010 | 02:08 PM
  #1164
Not a problem
Old 11-10-2010 | 08:22 AM
  #1165
Originally Posted by mgtmadness2007
So in theory, one could drop the crankshaft and P/S/R in the standard 121VR and get a bit more power? Didn't see anything about case mods in the release, just curious.
tromoly is offline
Old 11-10-2010 | 10:09 AM
  #1166
Snowbum32's Avatar
I was wondering the same thing
Snowbum32 is offline
Old 11-14-2010 | 03:54 PM
  #1167
MCR82's Avatar
Default Tune
Hi Guys,
I just replaced the bearings in my Reedy engine- which went perfect, I have just run a couple of tanks through but when i start to give it full throttle it dies. How do I retify this?
Thanks.
MCR82 is offline
Old 11-14-2010 | 03:57 PM
  #1168
Marcus Falconie's Avatar
Hi Guys,
Thanks.
Start with the glow plug, just because the engine runs it does not mean the plug is good. If that doesn't work go back to rich needles and start over.
Marcus Falconie is offline
Old 11-14-2010 | 04:31 PM
  #1169
MCR82's Avatar
Thanks mate - I'll give it a try....
MCR82 is offline
Old 11-15-2010 | 10:40 AM
  #1170
Rick Hohwart's Avatar
This is correct. The case is dimensionally the same. However we have upgraded the case material/production process as a running change to the VR and as standard on the VR-ST.
Rick Hohwart is offline
