REEDY .21 Nitro Engine
#1186
The Reedy ceramic is a little pricey but is a great quality bearing. I have noticed immediate and obvious power gains as soon as running the VR with a ceramic swap.
I can't gaurentee the proper fit of a Boca or TKO but here is a Boca link, looks like their ceramics are about $45 for the good one. In the past a couple guys tried to use the TKO but the fit wasn't correct on the OD. The deminsions are 14x25x6.
http://www.bocabearings.com/search.a...thOperator=%3d
Not sure if the bearing you get is the one pictured, but the Reedy bearing is made up of many more ceramic balls of a smaller size, and the Boca appears to be fewer and larger balls. The Reedy bearing is unique, and I'm sure this was engineered this way for a reason.
#1187
#1188
One page back I had said I sent both of my engines out and today I have received them both!
Rick Howart had me send them in and both were repaired and sent back.
Great Job Team Associated, Reedy, Rick Howart, and the Engine Rebuilder!!
Thank You Rick, Team Associated, Reedy Engines and the person who worked and repaired both of my Engines!!
I can't wait to run them both!!
#1193
what Glow plugs are best
