REEDY .21 Nitro Engine
#436
Plug = O.S. P4
Pipe = Factory Team 2035
Restrictor = 7 mm
Head Shims = 0.50 mm
Fuel = Sidewinder 30% World Blend
Top End Needle = 2 1/2 Turns Out From Bottom
Bottom End Needle = 3 1/4 Turns Out From Bottom
Temp = ~250 Degrees F
I would also put this motor in a RC8B, them OD cars are slow.
#438
I just took my first Reedy motor apart, I am modding one for a customer. From a appearance standpoint the box is awesome, casting on the block is the best I've seen, head is very nice. Machining looks great and the head button is cool. After digging into it I wonder why they went with the oiling hole in the crank like the Std. V-spec? The crank is chrome plated, have never seen that before but it might work good. The crank seems a little soft but the chrome should wear well. With some timing changes I think this motor will run really well. A few companies have tried to copy the V-spec but not one has ever copied everything.
Rex
Rex
#443
#444
#445
Usually AE will have a press release before a new product, then a bit later it actually becomes available, don't let a pro version down the road deter you from getting one now if that's what you were trying to figure it out. It may be a little while.
#446
Well, i had my second race with my Reedy this past weekend. Motor is really starting to come around. Temps around 250, and more power top and bottom then my GRP's ever had. I am ordering a new motor for my truggy this week.
I love the fact that they sound different flying down the straight then other motors.
So far, i have only tried a GRP 2053 pipe.
#450
