REEDY .21 Nitro Engine
Old 04-22-2010 | 12:03 PM
  #931
there has to be something else people are using...the stock bearing is a lil overpriced and to top it off not the best of quality...anyone????....
mist467 is offline
Old 04-25-2010 | 02:55 PM
  #932
Here is my quick review of the engine. i got it bolted the carb on and stripped out one of the bolt holes to hold it on. i used longer screws and carb sealer and did not tighten so much. metal on the case seems alittle soft. broke it in per manual not a problem at all. have about a half gallon in it now and two race weekends. my temps are around 245 when its 70 outside. bottom end is awesome and top not far behind the more expensive engines. im not here to say its faster than a speed or novarossi but its def. holds its own on the straight. only at the very end last 20 feet do i see where the others have a bit more top end. great engine for $230 just hope it lasts.
koreanassasom is offline
Old 04-25-2010 | 05:26 PM
  #933
Ultraspeed84's Avatar
But the question should be run time..
Ultraspeed84 is offline
Old 04-25-2010 | 07:03 PM
  #934
Both mine are about 10min per tank.
Fred Perkins is offline
Old 04-26-2010 | 03:07 AM
  #935
i was getting 7.5 min a tank+ didnt push it for engine is still being broken in. i am getting 11+ out of my rb b9 in truggy at the moment
Old 05-02-2010 | 12:41 PM
  #936
Hey guys what are the factory settings for this engine? I got one used and want to set it to factory so i can fire it up and tune it right thanks everyone!!!
Beenbreto is offline
Old 05-02-2010 | 03:36 PM
  #937
DiaRh34's Avatar
Got mine sealed brand new and it was HSN-2.5 turns out LSN-3.5 turns out
DiaRh34 is offline
Old 05-02-2010 | 05:07 PM
  #938
just ordered a new reedy engine, does it come with a plug ? if not what do you recomend ??
rcfunnn is offline
Old 05-02-2010 | 05:08 PM
  #939
DiaRh34's Avatar
It comes with a reedy plug, dont remember which one. I used it for break in and now I'm running p4's
DiaRh34 is offline
Old 05-02-2010 | 10:58 PM
  #940
Thanks going to try that today hope i get it fired up!!!
Old 05-05-2010 | 06:37 PM
  #941
Goomba_7's Avatar
I too have only used the Reedy plug for break in, but have successfully used the Odonnel 97T. So if you want to save a few bucks there's another option for you. Plus in my experience the 97T has lasted me a lot longer. I still have the one that I put in from last summer and it's running strong still. And if your not using it already you may want to switch to at least the 7mm venturi.
Goomba_7 is offline
Old 05-07-2010 | 02:04 PM
  #942
BSchorr's Avatar
R/C Tech Elite Member
When I got my Reedy... for some reason.. it didnt come with a plug.. I ran O.S. P3's in it.. but going to switch to 97T's like my GO GX-5R
BSchorr is offline
Old 05-07-2010 | 03:52 PM
  #943
ok trying to figure out which pipe to use, i have a jp3 or serio 2013 or rb 2045, anyone have experience with any of these pipes on this motor
skidoos is offline
Old 05-10-2010 | 08:46 PM
  #944
Reedy RT4 glow plugs for $8 a piece. Perfect for the Reedy motor especially during the hot months coming up.
I have 7 pieces left.
email: [email protected]
paypal: [email protected]
Apologies since this is not a for sale thread, but I thought some of you would be interested!!
bluebon88 is offline
Old 05-10-2010 | 08:52 PM
  #945
New Reedy Piston and Sleeve $75
New Reedy Con Rod, Pin, and C-clip $30
New Reedy Front and Rear Bearing $40
