REEDY .21 Nitro Engine
Old 02-02-2010 | 07:54 PM
  #781
slasher man's Avatar
Originally Posted by bcrazy
Bigedmond, I'll be headed your way for Silver State and I am looking for some help. I'll be running a Reedy in my RC8T that I have very little time on. It was broken in and I got a practice day out of it with the help of a couple AE drivers but ended up having the crank problem. I have not run it since I got it back from AE. I was thinking about trying to get it tuned a day or two before the SS race at the on road track if they will let us on there.
Would you be able to help?
Thank you Brian
i will be going to the ss race to is the reed ave great power
slasher man is offline
Old 02-03-2010 | 04:01 AM
  #782
Shane Racer's Avatar
Originally Posted by Goomba_7
Hey Guys, I'm curious what is the reason they put the extra shim in the box for??? Am I suppose to put this shim in after break in or remove the original shim? What is it's intent?
After break in take the two shims out that came in the engine and put the single one in that comes extra.
Shane Racer is offline
Old 02-03-2010 | 09:27 PM
  #783
Goomba_7's Avatar
Cool. Thanks Shane. appreciate it.
Goomba_7 is offline
Old 02-04-2010 | 12:43 PM
  #784
Jason Pelletier's Avatar
I got this motor when it came out and lemme tell you i still love it. I barely ever have to touch the needles and it runs solid 230-240 and gets 11 min a tank.
Just my long term review. It's S'easy. Not the fastest motor out there but still fast.
Jason Pelletier is offline
Old 02-04-2010 | 09:07 PM
  #785
pantera nitro's Avatar
Hi Guys,
just got a Reedy and am about to run it in.....
any tips or pointers to do or keep an eye out on?
and i have a couple of pipes to choose from my existing stuff and was wondering what you would recommend?
Go 2072
Go 0801
Go 2053
Novarossi 9901
i've seen a new AE pipe 2039 would that give a better top end than the 2035?
any feed back or info would be great!!!
Mike
pantera nitro is offline
Old 02-06-2010 | 10:35 PM
  #786
Goomba_7's Avatar
If you read the press release about the new Reedy pipes they state the 2035 is for ground ripping bottom end where as the 2039 will help up top. As for your existing pipes, I'm not too familiar with what # pipe is good for what, Just remember the longer the pipe the more bottom end it will produce. The shorter the pipe the more top end you'll get. The 2035 pipe which i just recently got, is one of the longest pipes I've seen it runs almost the entire length of the side dirt guards on my RC8B.
Goomba_7 is offline
Old 02-07-2010 | 01:15 AM
  #787
1bigshane's Avatar
Originally Posted by pantera nitro
Hi Guys,
Go 2072
Go 0801
Go 2053
Novarossi 9901
Mike
ya! your temps! they dont like to run over 280,the crank melts!
1bigshane is offline
Old 02-07-2010 | 06:40 AM
  #788
sandy111's Avatar
Has anyone tried a 2013 pipe with the reedy.
sandy111 is offline
Old 02-07-2010 | 08:15 PM
  #789
alrighty cool,
my Go pipes are a lot longer than the Nova.
i guess a bit of trial and error is on the cards then
thanks fella's
and i'll try not to melt anything lol
Old 02-08-2010 | 05:20 AM
  #790
Brandon Melton's Avatar
I haven't tried it personally, but a local racer did and the car looked strong everywhere. He didn't comment on comparisons to anything else, but it sounded strong and power band looked good from trackside.
Brandon Melton is offline
Old 02-08-2010 | 10:44 AM
  #791
sandy111's Avatar
Brandon do you know what his run time was with the 2013
sandy111 is offline
Old 02-15-2010 | 03:19 PM
  #792
Goomba_7's Avatar
Hello there Guys. I was curious what kind of run times everyone is getting with the 7mm restrictor?? I know my tune is pretty damn rich right now but I would like to get an Idea. I just ran in a big local race this weekend and I maybe got 7mins and change. I'm running about 240 at race pace and it feels really good. When I try to adjust either needle at this point the power seems to drop off so I tend to go back to where I'm at. Let me know. OH for reference I believe I'm at about 2 turns out from bottom on the top needle and in about a half from flush on the low.
Goomba_7 is offline
Old 02-15-2010 | 03:37 PM
  #793
JoeyTheRocket's Avatar
9:45-10:15 @ Leisure Hours
17T bell, stock pinion, 2035 pipe, 97T plug
JoeyTheRocket is offline
Old 02-15-2010 | 04:18 PM
  #794
Goomba_7's Avatar
well then i'm way too fat then won't you know.
Goomba_7 is offline
Old 02-15-2010 | 04:23 PM
  #795
Just play with your bottom end, the top end is very touchy. I'll be at the track next Saturday if you need anything.
