Trinity EXTECH .21
Old 10-18-2009 | 07:37 PM
  #1906
chevydc44's Avatar
I took my motor apart and it had rust on the crank and the bearings it was pre-run and my case has a crack on it i cantacted chad numerous times and said he was gonna send a new case this was like 3 months ago and still no case so i have to say customer service is not good sorry to say
chevydc44 is offline
Old 10-18-2009 | 08:00 PM
  #1907
wfo's Avatar
wfo
From: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
stick to NINJA !!!!!
wfo is offline
Old 10-18-2009 | 08:04 PM
  #1908
chevydc44's Avatar
Lmao u know it wud up fool
Old 11-11-2009 | 10:21 AM
  #1909
bigjayjay1's Avatar
Default .24 EBMOD
I know this the .21 thread but for the .24 EBMOD version what pipe works the best for this mill
bigjayjay1 is offline
Old 11-11-2009 | 10:32 AM
  #1910
Trey7's Avatar
the 2056 or the 2057 work good with this motor. the 2013 has to much bottom for the motor and you loose run time due to it.Most of the guys are running the baseball bat pipe.
Trey7 is offline
Old 11-11-2009 | 10:49 AM
  #1911
bigjayjay1's Avatar
Thanks currently running the OS2050
Old 11-12-2009 | 07:38 PM
  #1912
bigjayjay1's Avatar
.24 carb is sticky less then a gallon is this normal for the extechs is the barrel can i use a OS
Old 11-12-2009 | 07:44 PM
  #1913
Trey7's Avatar
I have heard problem with the losi's due to the angle, what I have heard is to remove the barrel and polish it and try and get you servo to pull straight out on the carb, any angle will put it in a bind and cause it to stick.
Trey7 is offline
Old 11-22-2009 | 11:02 AM
  #1914
Rick57's Avatar
I have a first generation non-modified EX Tech .21 (40060) that I would like to rebuild. It needs connecting rod. I cannot find one anywhere. After doing some research, it appears the WERKS rods are interchangeable. Specifically part# WRXTL21070010. I would like to know where I can get some wrist pin clips as well. Can someone "in the know" verify this for me? Amain has them in stock. Also can some verify the stock head sim set up as well? The engine has been sitting on my work bench (in parts) for some time. I think it came with 3 shims.
Rick
Rick57 is offline
Old 11-22-2009 | 11:13 AM
  #1915
selling a less then Gallon race prep extech.24 still has metal metal pinch ,needs to finish breakin. $120 shipped. pm or [email protected]
jmoneym is offline
Old 11-24-2009 | 08:36 PM
  #1916
rcboxer's Avatar
Does anybody know the stock carb settings for the extech .24 by chance? Thanks
rcboxer is offline
Old 11-24-2009 | 08:51 PM
  #1917
DezSlash's Avatar
heres the stuff for the full mod that i run. http://www.teamepiconline.com/pdf/fullymod.pdf
DezSlash is offline
Old 11-24-2009 | 09:43 PM
  #1918
BIG RE's Avatar
Does anyone know where Chad got his 5.5 restrictors? The smallest I can find is a 7 for Sirio/Werks, and a 6 from innovative designs.
BIG RE is offline
Old 11-25-2009 | 06:09 AM
  #1919
cdbias's Avatar
I think the Werks website list's them but they are never in stock. My understanding is that Trinity was supposed to be getting some in stock.
cdbias is offline
Old 11-25-2009 | 12:16 PM
  #1920
BIG RE's Avatar
ok, thanks
BIG RE is offline
