Trinity EXTECH .21
Old 05-26-2009 | 07:54 PM
  #1591
David Wall's Avatar
My 21 comes off from a 30 min a main saturday night at 168 degrees and getting 10 minutes on a tank of fuel..got to love that!!
David Wall is offline
Old 05-26-2009 | 10:13 PM
  #1592
chevydc44's Avatar
Nice what are ur settings on your needles
chevydc44 is offline
Old 05-26-2009 | 10:59 PM
  #1593
DRRC's Avatar
where can i get an extech 21 engine coz i am in need of a good engine that i dont have to break in and what pipe to use
thanks
DRRC is offline
Old 05-27-2009 | 05:52 AM
  #1594
Tim Dougherty's Avatar
Originally Posted by chevydc44
What other carb can i use on extech .21
A GRP carb will work and a Novarossi for .21
Tim Dougherty is offline
Old 05-27-2009 | 06:36 AM
  #1595
I need a new head button for my Race Prepped .21 and A-main is out. Anyone know which of the Siro or Werks turbo head buttons will work?
cjtamu is offline
Old 05-27-2009 | 09:13 AM
  #1596
chevydc44's Avatar
Cool thanx so basicially i can use the carb off my RB
Old 05-27-2009 | 10:10 AM
  #1597
what size is the inner bearing on the .24?? tks
P.LOWERY is offline
Old 05-27-2009 | 10:42 AM
  #1598
Suspended
Neither i have tried that before and you will never get the right tune on the engine. I dont care what anybody tells you. Id call Trinity to see if they have any instock
boogeyman is offline
Old 05-27-2009 | 10:54 AM
  #1599
Rick57's Avatar
I was tearing down my Extech .21 to replace the connecting rod and noticed there were no head shims. Is that normal? My RB came with 2 from the factory. I was thinking about using my RB carb as well. Any feed back as to how it performs as well as base line needle settings? As far as Dishsoap’s issues are concerned, mine acted the some way and it turned out to be a worn out connecting rod where it connected to the crankshaft pin.
Rick
Rick57 is offline
Old 05-27-2009 | 11:11 AM
  #1600
PinoyCali's Avatar
Hello Rick,
Is this the extech 1 or 2?
Pay close attention on bottom of the cooling head the shims are silver.
Rick
PinoyCali is offline
Old 05-27-2009 | 11:14 AM
  #1601
Rick57's Avatar
Thanks! I will take a look tonight.
Rick
Rick57 is offline
Old 05-27-2009 | 11:17 AM
  #1602
Rick57's Avatar
Originally Posted by PinoyCali
Hello Rick,
I am not sure. I bought it over the Xmas holidays. It is not modified. It is box stock.
Rick57 is offline
Old 05-27-2009 | 02:03 PM
  #1603
David Wall's Avatar
Would have to check them out, I do not go by so many turns in our out from flush, I tune to conditions. Saturday was in high 80's, saturday night, temps dropped down into the mid 60's.
Old 05-27-2009 | 02:57 PM
  #1604
Rick57's Avatar
It is a part number TRI40060. How many shims should the be?
Rick
Rick57 is offline
Old 05-27-2009 | 03:22 PM
  #1605
You get the mill close to that 185 mark and then tune from there. Run a good hard clean lap & check your time, smoke, & temp. Then give it another run & check that time/temp/smoke. This is a very efficient motor, not alot of heat escapes it so your temp gun reads cooler temps then most other motors will read in.
party_wagon is offline
