Trinity EXTECH .21
Old 05-13-2009 | 01:49 PM
  #1546
smracer31's Avatar
What address do i send my stuff to? I know they are in the process of moving, i don't want to send my stuff to florida and have nobody around to accept the delivery.
smracer31 is offline
Old 05-13-2009 | 02:57 PM
  #1547
EBMods's Avatar
Default BAD INFO
ok, this is getting real old. And I can't blame anyone except for Chad. As he is telling people this BS. So what I have done is forwarded this thread to the owner of Star Motor, Andrea Rossi, and asked him in email, If this was something he told Chad or something he diagnosed himself. And he replied that he has never said anything negative about me or my process.
SO here's the fact about the crank pictured above, it's wasn't caused from "Quick Break-In" but from the crankshaft moving in and out during running.
I hope this helps. Now please stop spreading false diagnoses, as the facts prove engines that I've broken in last longer, and make more power..... Chad knows this because he ran my OS V-Specs for years prior with great results because I would break them in for him. This was the reasoning for me to offer this service on the ExTech engines.
So the only problem I've had is from Chad putting this into peoples heads. So now with the online post multiple people saying that Chad has told them this. Now I have proof of malicious and deviant intentions to ruin my business because I Left Trinity,, REMEMBER I DIDN"T GET FIRED BUT I QUIT, I told them to hit the road.
I hold no hard feelings to anyone who has been given this bad info. But please stop spreading lies.... PLEASE!
EBMods is offline
Old 05-13-2009 | 04:34 PM
  #1548
smracer31's Avatar
Im confused as to how the crankshaft would move in and out during runningdoesn't the flywheel and collet when tightened down keep it from doing this? or is it a problem with the motor that allows it to move?
Old 05-13-2009 | 04:51 PM
  #1549
EBMods's Avatar
The flywheel will clinch down where the collet sets. It will not slide back and take up any slop automatically when you tighten down the nut. You have to make sure the crank is pulled forward all the way when mounting your flywheel.
EBMods is offline
Old 05-13-2009 | 06:45 PM
  #1550
smracer31's Avatar
This is exactly how i mount my flywheel, i tug the crank forward while sliding the collect down to ensure there is no play, so im still baffled as to why my crank has worn like this and has lost its compression after 1.25 gallons.
btw, Im not, nor ever have said you were to blame ed, im simply stating the issues im having with my motor.
Old 05-16-2009 | 11:04 AM
  #1551
Rick57's Avatar
I have a non modified Trinity Etech .21. The connecting rod has gone bad with around 1.5 gallons on it. A connecting rod is no where to be found. And with Trinity moving to Florida, the situation is even more challenging! Is there another brand connecting rod that will work? I know I did not spend tons of money, but I would think I would get more than a gallon and a half. Is Trinity getting out of the nitro engine business? I have noticed some hobby shop running sales on Trinity nitro parts. Blowing out inventory?
Rick
Rick57 is offline
Old 05-16-2009 | 11:45 AM
  #1552
1armed1's Avatar
Rick
The Sirio and werks rod ending in part number 070012 is a direct fit.
I just installed a new one in mine.
Amain has them in stock and there was a guy on here in the forsale thread that had one.
Do a search in the sale forums for " sirio rod"
later
Dayton
1armed1 is offline
Old 05-16-2009 | 12:57 PM
  #1553
Rick57's Avatar
Smile
Thanks Dayton! Would this be the same case for other engine parts; crank, piston, wrist pin, etc.?
Rick57 is offline
Old 05-16-2009 | 01:00 PM
  #1554
1armed1's Avatar
I found out which rod was needed by speaking with Ed (eb mods), he told me to get the evo IV rod.
I imagine the rest of the parts are the same or atleast will interchange.
Ed or someone from Sirio could give you a better answer.
1armed1 is offline
Old 05-17-2009 | 01:07 PM
  #1555
RcRick's Avatar
Will a carb from a Sirio work on a EXTEC?
RcRick is offline
Old 05-17-2009 | 01:14 PM
  #1556
1armed1's Avatar
Same carb
1armed1 is offline
Old 05-17-2009 | 01:58 PM
  #1557
RcRick's Avatar
RcRick is offline
Old 05-17-2009 | 02:54 PM
  #1558
chevydc44's Avatar
Default Trinity Extech .21
I was wondering what carb can you use on the trinity .21
chevydc44 is offline
Old 05-17-2009 | 07:28 PM
  #1559
Default extech 24 and big boy pipe
I'm having a couple of issues myself. I have the FM 24 and the heat sink broke at the base and came off. the baffling in my pipe is loose also so it make a nice rattling sound. I knew the exhaust note kept changing. I got one of the first ones out and thought this was an isolated issue. I for one would be glad to hear when Trinity/Epic is back up and running.
just a fyi, a Nova P5 heatsink fits. I haven't had a chance to temp the motor, but it seems to run well.
bottomline2000 is offline
Old 05-18-2009 | 06:01 AM
  #1560
Team Chambers's Avatar
[QUOTE=bottomline2000;5824833] I for one would be glad to hear when Trinity/Epic is back up and running.
QUOTE]
Chad said June 1 at the earliest.
Team Chambers is offline
