Like Tree2Likes
GRP... Engine... Thread...
Old 03-18-2009 | 03:33 AM
  #1186
Originally Posted by marccaracer
Tried to order a tuned 28 today and was told that the engine is discontinued and out of stock.
Is this engine now discontinued?
try mark smith at www.powerhousercperformance.com
he posted on his thread that he has some grp .28"s with his race port on them for like 280.00$ go to his web site and call him on the phone from the contact link ...mark is a great guy ,,,and does super work on motors ....tell him zixxer sent you ...
zixxer is offline
Old 03-18-2009 | 08:07 PM
  #1187
maxx90's Avatar
Default grp
Hey guys I just bought my non tuned 21 today and the tuned promo will be here tommorrow. I will be starting the breakin friday. I have a couple of questions. Are ya'll sealing your motors or do they have a good seal? and the pipe that comes with the tuned version does it work well with the non tuned I have several different ones I can put on it. thnx MW
maxx90 is offline
Old 03-20-2009 | 09:47 AM
  #1188
tristyn's Avatar
HEY, I have a GRP.21 & GRP.28 tuned with aprox. 3gallons on each 1. I'm getting ready to install new ceramic bearings in both this weekend. The bearings I bought are TKO ceramics. I noticed the front bearings are rubber sealed on both sides. Should I take the seal off of the inner front bearing so that it can be lubricated thanks
tristyn is offline
Old 03-20-2009 | 11:07 AM
  #1189
leave both seals on
SupermaxxRich is offline
Old 03-20-2009 | 02:09 PM
  #1190
maxx90's Avatar
Default grp
Can someone answer my qoute questions? I also got my tuned version today. And as luck would have it I got the pit towel and wanted the hat. I am a hat person. Anybody want to trade? thnx MW
maxx90 is offline
Old 03-20-2009 | 03:39 PM
  #1191
I'm not really sure about your question but if you dont want the towel i'll take it!!! I am using the non tuned with an 086 and its pretty good.
rgrassey@me.com is offline
Old 03-20-2009 | 06:59 PM
  #1192
tristyn's Avatar
maxx90, I seal all my engines
tristyn is offline
Old 03-20-2009 | 07:43 PM
  #1193
Frank L's Avatar
I seal all my engines to prevent any problems. I haven't had and with the 3 grp's I have but I don't want to take the chance. It doesn't matter what engine I run I seal it from the beginning. As for pipe dynamite 086 or 053 the grp 2053 is on the restrictive side and the trinity bad boy pipe was terrible lasted 2 laps and has been new and shiny in my pit box ever since.
Frank L is offline
Old 03-20-2009 | 08:38 PM
  #1194
rcboxer's Avatar
Hey guys, silly question here. When you set your idle stop screw, do you set it to the correct spot with the carb restrictors out or with them in? Also, when you change from a 6mm to a 7mm restrictor do you have to readjust your idle? thanks
rcboxer is offline
Old 03-20-2009 | 10:22 PM
  #1195
maxx90's Avatar
Default grp
Thnx guys anyone need a pit towel I need a hat.
maxx90 is offline
Old 03-20-2009 | 10:54 PM
  #1196
Poppin Fresh's Avatar
Which GRP plug do you prefer? The 4 or 5?
Poppin Fresh is offline
Old 03-20-2009 | 11:39 PM
  #1197
tristyn's Avatar
I run a 4 in the GRP.21 and 5 in the GRP.28. works good for me
tristyn is offline
Old 03-20-2009 | 11:46 PM
  #1198
I have a tuned .28 and a modded .21. I only sealed both sides of the pinch bold on both engines and they have been perfect so far. i don't have much runtime on them yet. I'll start sealing the carb next time I take them apart, just to be sure.
I just got a 2053 pipe to try on the tuned .28. From what I hear, the pipe holds the engine back a bit, but in exchange you get very good runtime. I first tried a MSR 1005 w/6mm restrictor and was not to impressed. It did run good, but not the power I expected from a 28. The engine was still very tight and should get better as it loosens up. My Powerhouse modded .21 has a JP-1 pipe (recommended) on it. With a 6mm restrictor and the engine is still very tight, preformance was just good. I changed to a 7mm restrictor and have not yet ran it again.
I still have a couple of pipes to try.
2050
2060
might buy an 053
John Schafer is offline
Old 03-21-2009 | 12:56 AM
  #1199
99problems's Avatar
Great motors easy to tune I have 6 of them
99problems is offline
Old 03-21-2009 | 09:57 AM
  #1200
tony montana's Avatar
I dont run grp plugs in my tuned anymore , I run o.s. p3's. It seems easier to tune to me with the p3. plus they are alot cheaper. You are correct with the 2053 pipe. Runtime is really good with it
tony montana is offline
