Like Tree2Likes
GRP... Engine... Thread...
Old 12-20-2008 | 07:49 PM
  #766
Originally Posted by zixxer
for anyone wanting to put the glow plug question to rest ...it is rested ...the odonells plugs work perfectly in the grp motor ...no problems at all....put 3 tanks on it today to get started breakin it in ....after dumping the way overpriced and non working out of the box grp plug it was smooth sailing ...the motor stayed at 217 degrees for most of all 3 tanks ....never missed a lick ...my buddy over at my house even said ...my god will that motor ever quit idling .....will probably get the rest of it done tomarrow ....will post on how it goes ....i should be putting some video of it up on youtube tomarrow night ....
Which Odonells plug did you use?
rstnboy is offline
Old 12-20-2008 | 08:01 PM
  #767
r1harper's Avatar
what size carb insert comes with the non tuned engine..thanks
r1harper is offline
Old 12-20-2008 | 08:10 PM
  #768
Originally Posted by bherzog513
What is the suggested needle settings on a the tuned motor, and what comes from the box?
i measured mine last night for another thread ...from the factory my needles were
hsn 3-1/2 turns out from bottom
lsn 6-1/4 turns out from bottom
originally thought i would have to lean it a bunch to get it started ...put only 1-1/2 turns in form factory on the lsn ...and 1/2 turn in from factory on the hsn ....fired right up ...didnt turn the needles a bunch after that ...just for break in ....
i used a 97t medium....after a little more fuel i will probably go to a 77t hot
they work great ....and last a long time
8mm and amains got it on sale for 219$
zixxer is offline
Old 12-20-2008 | 08:48 PM
  #769
I got the non tuned version.. (.21)
Um, do I need to add any shims to the head if I'm goin to run 30%?
rrawrrrrr is offline
Old 12-21-2008 | 05:41 AM
  #770
r1harper's Avatar
i got one from my lhs for $199
r1harper is offline
Old 12-21-2008 | 07:17 AM
  #771
im not sure on the non tuned ...the tuned comes shimed for 30% i will do some digging around to see what i can find .....
zixxer is offline
Old 12-21-2008 | 08:17 AM
  #772
desertbird's Avatar
You can always take the head off and see what shims are in there. If there are 2 you can take 1 out. If they are different thicknesses I think you take the thicker one, not sure though.
desertbird is offline
Old 12-21-2008 | 09:35 AM
  #773
maycam10's Avatar
there is a guy at my local track who is on his 12th or 13th gallon. it has been pinched a couple times but his grp absolutely screams . whenever i have the money i will have one myself.
maycam10 is offline
Old 12-21-2008 | 09:55 AM
  #774
Alright, thanks.
if all goes well with the Non Tuned chances are I'll be picking up the tuned version in Spring
Old 12-21-2008 | 10:05 AM
  #775
puba187's Avatar
that was me. that motor sat and idled for at least an hour straight i think it died once during the entire day. i gotta say it did look promising. and yes the odonell plug worked like a champ.
puba187 is offline
Old 12-21-2008 | 10:43 AM
  #776
Djballen's Avatar
I'm to lazy to go threw this entire thread. Does any one have a link to Adam Drake's WOT break in method? Thanks
Djballen is offline
Old 12-21-2008 | 10:57 AM
  #777
you need to call burton ...he will tell you from racing on the same team as the drake ...the best way to break it in ....i went with it ...eventhough it was different than the way ive broke in my last 3 engines ....dont know if hes using the wot method any more ....? it was in an xtreme rc issue about 4 months ago ...i understand it ..but dont know if i will ever use it
zixxer is offline
Old 12-21-2008 | 11:59 AM
  #778
GMS_Racing's Avatar
Just ordered my non-tuned .21 from amain today..just wondering what pipe your guys are running on this motor? thanks
GMS_Racing is offline
Old 12-21-2008 | 01:07 PM
  #779
053 dyn, 2053 grp, 2035 ttr ...is what ive seen people saying thye used on the tuned version ...would think they would hold to the non-tuned ....
zixxer is offline
Old 12-21-2008 | 01:10 PM
  #780
losi_racer's Avatar
jp 3 ive heard also
losi_racer is offline
