Like Tree2Likes
GRP... Engine... Thread...
Old 12-03-2008 | 04:20 PM
  #676
Originally Posted by Chill_Will
So you saying the OD plugs work too?
yo chill im gonna save you some reading .... it seems and i have seen first hand ....that if you run say an o.s. plug ...or any other type plug in it ...you may have to stick with that brand ...it is possible there are slightly different tapers on turbo plugs ...what this causes is fuel spitting out from around where the glow plug fits into the head ....heres the scenario i witnessed first hand ......
grp plug bad out of box
used o.s. p-3
when o.s. p-3 blew out
tried odonells plug
motor wouldnt run because glow plug wouldnt seal and spit fuel out
solution ....put new p-3 plug in worked like a champ ...and is still working and using p-3 plug ....
i know first hand that odonells plugs will work fine ...i just dont know if you will be able to run any other plug in it ....hope that helped
zixxer is offline
Old 12-03-2008 | 04:22 PM
  #677
Originally Posted by ABURTON
Have any of you guys tried this engine? What did you think about it?
http://www.carolinasrc.com/Webstore/...dproduct=10021
if the grp tuned runs the way i think it will ...i will be picking up one of those to run at smaller club races ....
zixxer is offline
Old 12-03-2008 | 04:25 PM
  #678
Anyone have any carb restrictors they want to be rid of for the GRP .21 tuned? Size 6 or 6.5? Pm me.
Also are there any other brand carb restrictors that will work with these carbs?
not sure if the idrc inserts will work ...have asked ... but not sure ...if they do i have a 7mm you can have ....im getting the promo kit and it comes with the 8.7.6 i think is what porter told me
zixxer is offline
Old 12-03-2008 | 04:29 PM
  #679
tony montana's Avatar
Im not paying 15 bucks for a grp plug, I get almost 2 p3's for the price of a grp, plus the engine runs better on the p3
tony montana is offline
Old 12-03-2008 | 04:33 PM
  #680
word up hommie ...i just dont have good luck with o.s. thats why im goin the od route ...but alot of people run p-3's .....alot of people
zixxer is offline
Old 12-03-2008 | 04:54 PM
  #681
I havent tried the od plug in my grp but I do run them in the rb s7, the standard 99 and they work great
Old 12-03-2008 | 05:53 PM
  #682
no doubt ...i started runnin em in my gotech's and man they just work ....or well better for me than anything else out there
zixxer is offline
Old 12-03-2008 | 07:53 PM
  #683
Frank L's Avatar
I use an OS p7 plug in my GRP .21 tuned (I just like to run medium plugs). I have used a p7 plug since the engine was new and have never had a problem. This engine now has 5+ gallons of fuel through it and it still runs strong. Also I notice no difference when I switch to a GRP plug. Personally I like OS plugs over any other brand. In my opinion they last longer and tune easier. I don’t know what the big deal with non GRP plugs not sealing as well in GRP engines is.
Frank L is offline
Old 12-03-2008 | 10:13 PM
  #684
Default GRP Ninja head button problem
Just wanted to comment on spitting fuel out of head button. I own 3 GRP Ninjas. Two are .28 and one is a .21 . Two of the engines would only use OS plugs and ninja plugs with no leaking. The other one would only use Ninja plugs, all OS plugs would leak . My buddy I race with has a Ninja .28, and his leaks with OS plugs but not with Ninja plugs. After this many GRP engines, and this many issues, I figure there has to be a factory defect with the head button. Its a good thing I love the way they run , and the 10 gallons I got on the .21.
Truggyman is offline
Old 12-03-2008 | 10:24 PM
  #685
Chill_Will's Avatar
Thanks for the info Zixxer. My motor is not new and the guy before me ran the GRP plugs. I might have to buy me another button. It will save me money in the long run.
Chill_Will is offline
Old 12-04-2008 | 03:21 AM
  #686
try some diff brands as it wont hurt it ...but you know what to look for....
zixxer is offline
Old 12-04-2008 | 12:18 PM
  #687
jamminbce's Avatar
Default grp 28 pipe
hey guys im wondering whos had good results with 053 or 086 pipes. Ive got it geared well for the power just wondering on pipe selection.
jamminbce is offline
Old 12-05-2008 | 04:50 PM
  #688
just got mine today and i dont see alot of difference in the 2053 that comes with it and my 053dyn ...but im sure there are internal differences ...try em both and post up ...i have the 053 and 086 wouldnt mind trying em out .....
zixxer is offline
Old 12-05-2008 | 08:03 PM
  #689
s porter's Avatar
Only difference I know of between the Ofna 053 and the GRP2053 is the latter is EFRA legal...The Ofna is not. The 053 will probably perform better, maybe at the cost of fuel mileage depending on your trigger finger.
s porter is offline
Old 12-05-2008 | 08:20 PM
  #690
jamminbce's Avatar
Default grp 28 pipe
thanks guys anyone tried the os 2050 with the 28
