Like Tree2Likes
GRP... Engine... Thread...
Old 03-12-2010 | 12:16 AM
  #1966
TecnoPower's Avatar
Originally Posted by Tony899
If they wanted to reuse the previous designs from the GRP engines, why didn't they take them out before they set the fire?
The main supplier for the GRP engines was not expecting this event...
TecnoPower is offline
Old 03-12-2010 | 04:43 AM
  #1967
teamlosi906's Avatar
Default grp
any release date for the motors and parts if these are any thing like the tuned 21 they are going to sell like hot cakes
teamlosi906 is offline
Old 03-12-2010 | 04:50 AM
  #1968
Default grp
Originally Posted by bigjayjay1
Yeah the deal really sucked wind when the plant caught on fire the GRP is a solid buggy motor /// some people made some good extra $$$ on the his conrod purchase each sold for over a 100 bucks thats called supply and demand that was awesome just missed that posting like always.
i had 10 rods before that purchase bought every grp part i could find there is still rods for sale on ebay from other people going for around the 100.00 mark p/s also
Old 03-12-2010 | 06:18 AM
  #1969
TecnoPower's Avatar
Spare-parts for the previous GT01-21BU are available here, this engine can be supplied under a different label to a good distributor if he feels like it. As said before we are in contact with Mugen USA.
Rody
Old 03-12-2010 | 08:32 AM
  #1970
Chris Peralta's Avatar
Rody, sent you a PM.
Chris Peralta is offline
Old 03-12-2010 | 09:50 AM
  #1971
Default motor
sent you a pm
Old 03-14-2010 | 10:13 AM
  #1972
Corey43's Avatar
here is a link to some GRP Stuff for sale
http://www.rctech.net/forum/r-c-item...ml#post7134264
Corey43 is offline
Old 03-14-2010 | 05:28 PM
  #1973
madweazl's Avatar
I ran the GRP for the first time today (picked up used). With the 2053 pipe this thing has a lot of punch; instant acceleration. I've read comments stating it was light on low end grunt but this one is a monster on the bottom with the GRP pipe. I'd like to get a little more top out of it, is there a pipe better suited for that? I'm using a 6 or 6.5mm carb restrictor.
madweazl is offline
Old 03-26-2010 | 07:49 PM
  #1974
madweazl's Avatar
Ran the Losi 350 with the 2053 last weekend and it was a frickin monster. Better than the GRP throughout the RPM range. Does the 6.5mm restrictor kill that much top end? I havent pulled it out yet but plan on trying it out this weekend but it is just flat out dead on the top end right now. Like I stated earlier, low end punch is awesome.
madweazl is offline
Old 03-26-2010 | 08:18 PM
  #1975
jjshbetz11's Avatar
they scream on the top end. My .21 tuned is my backup now to the b5( still run the 2053) They are weird talking about tuning. They love to be fat on the bottom, lean on the top. Shame about replacement parts, would still be in my buggy if it wasn't for finding parts. By far the easiest do drive engine i ever owned.
jjshbetz11 is offline
Old 03-26-2010 | 08:25 PM
  #1976
madweazl's Avatar
I didnt notice a whole lot of difference in performance messing with the high side needle but the low side needle made significant changes to the performance of the engine. I know the engines can perform, just not sure what it wants as it reacts different than the rest of the engines I've run.
madweazl is offline
Old 03-26-2010 | 08:35 PM
  #1977
jjshbetz11's Avatar
ya they are VERRY touchy to tune. The easiest time I had tuning one was with a GRP plug. With a P3 its verry touchy. A P5 gave a bigger tuning window. I serisouly lost count on thee amount of gallons of fuel through mine, but it's high.
Old 04-27-2010 | 01:24 PM
  #1978
onge65's Avatar
Does anyone know what the dimension are for the carb needle orings on the GRP motor ? I need to replace one and It would be a big help.Or were can I get some? Thanks
onge65 is offline
Old 04-28-2010 | 09:52 AM
  #1979
Default GRP SILVER TOP
I want to start racing this year and I'm considering picking up a GRP silver top .21 from a friend for my kyosho st-rr. I't only has a 1/2 gallon on it. Is this engine considered broken in with only a 1/2 gallon through it? Does anyone have any information about this engine? Whats a good pipe for this engine? I'll probably be running the st-rr at revelation raceway in Ontario, California. Any Info would be greatly appreciated. I can't seem to find any info on the Silver top anywhere on the net.
Thanks in advance.
alvintimothyjr is offline
Old 04-28-2010 | 10:17 AM
  #1980
khudzik's Avatar
Thanks in advance.
Here's the description of the silver head from our site, it's kind of generic but I hope it'll help you somewhat.
"LOSR2001 Losi GRP Engine, Buggy .21. The GRP .21 Buggy Engine is designed in Italy by GRP, under the direct technical supervision of Mario Rossi.
This 1/8-scale non-tuned racing engine is produced with high-quality materials and undergoes a thorough manufacturing process. The engine's Temperature Control System (TCS) keeps the heat from the block from transferring to the carburetor causing intake changes and running out of tune.
All of the components used in the non-tuned engines are interchangeable with GRP’s tuned engine parts. This allows the non-tuned engines to be customized for increased performance, while eliminating the need to purchase a new engine. Each engine comes in a GRP plastic box, complete with decals.
Type: 1/8 Buggy
Displacement: .21 cu in
Bore: 16.27mm
Stroke: 16.79mm
Engine (Only) Weight: 355 g
Crankshaft Threads: 14mm
RPM Range: Up to 38,000 rpm
Fuel: Nitromethane
Cylinder Type: ABC
# of Ports: 5
Carb Type: Aluminum"
I ran one in my Losi 8-T 2.0 truggy and loved it. Not as touchy to tune as the tuned versions but still plenty powerful.
www.overdriverc.com
khudzik is offline
