RB Concept Engine Thread
#62
hello CDS70
my apologies for the delay in getting back with you, there was info on the pipe i was waiting for from the factory and i got it yesterday
the 2611 pipe might be discontinued from the factory according to an email i recieved yesterday, i am trying to confirm that this is true, this is part of the reason i was hesitant in getting back with you on this question. i did not want to hype up the 2611 only for it to not be available
the 2611 pipe is a star based pipe where as the 2604 pipe is a nova based pipe. The 2604 is meant for use with the R3 and the V12's but can be used also with the matrix r and rw's with great success
if you have been running the 2604 with success i would stick with it to be honest, the 2611 might of offered a bit more run time or midrange but with its being discontinued it will no longer matter.
you can always experiement with other brands of pipes but sometimes if you found one that works with why mess with success
thanks
kevin @ RB USA
thanks
kevin @ RB USA
#63
hello gary h
the C6BBT is our best selling engine these days.
the reliability has alot to do with your tuning abilities and how well you maintain the engine and the car.
in general we have very few problems with the engine. the use of turbo glowplugs was once thought to make the engines more difficult to tune but this is not true.
the engines will be very user friendly so long as you make sure all of the components that work with it are in good working order. clutch maintenance is very importaing with how the engine will tune, making sure your clutch bell bearings are in good working order will make a diference in how the engine tunes, bad bearings can cause engine tuning problems, worn clutch springs can create drag causing unexpected flameouts. these are the sorts of things i mean when i say maintaining the car
the OS is a great engine line and all of their engines perform well, or at least as well as the price related to the engine. The RG motor of theirs is a great engine for the price but wont run as hard as the SPEED V-spec, but then again look at the cost difference. Is one better to tune or more reliable than the other, probably not so keep this in mind with our engines as well.
hope that helps and please ask away if you have any other questions
thank you
kevin @ RB USA
thank you
kevin @ RB USA
#65
hey all
i recently just bought a Matrix rw
and have had one litre and about 6~7 tanks throught it and was wondering should there still be a lot of pinch or just verry litle as mine still got a bit of pinch
Any comments would be apreciated
Cheers Chris
and have had one litre and about 6~7 tanks throught it and was wondering should there still be a lot of pinch or just verry litle as mine still got a bit of pinchAny comments would be apreciated
Cheers Chris
#67
6Likes
