Like Tree6Likes
RB Concept Engine Thread
Old 04-05-2008 | 08:46 AM
  #91
Originally Posted by CIMRI
Acctually it is to hot. If you run long finals in this deg. You will loose after 15 min. your power! I had the same problems with my mm 353. I have to run the engine about 270 F. But after 15 min the engine loose power and I have to richen the engine. but under 270F is the engine not fast enough. The most importend is, How long did you drove the engine 310-320F ?
My last race was a 30 min main. I clipped a barrier 1/2 way through & performance was down after that but I can't say that it was the motor because the crash likely compromised my set up. I checked tightness/compression the other day & it still is very tight. I was also running a G4s with stock transmission. They have an ED tranny for it which is supposed to lighten the load on the engine. I just picked up that mod so hopefully my temps will go down from there. Also note that I always fatten up the top end a little after qualifying as I also feel that over a long run you don't want it that lean.
GBagRacing is offline
Old 04-05-2008 | 07:04 PM
  #92
Woodlands Racer's Avatar
Hey dremmelboy,
I've noticed that the Circut C-6 is no longer listed as an option on the RB web site. Only two off-road motors and the Rody C-6. Has the standard C-6 been discontinued? If so what new option is RB offering that is not a tune motor for the .21 on-road car?
Thanks in advance for your response,
Roger
Woodlands Racer is offline
Old 04-06-2008 | 05:02 PM
  #93
keavze's Avatar
anyone got the stock settings for HSN and LSN of a RB V12 5P?
keavze is offline
Old 04-07-2008 | 08:50 AM
  #94
HSN 3.5 LSN 5 for the 01700-000510.
Old 04-07-2008 | 10:15 AM
  #95
spenzalii's Avatar
Hey guys.
I have an older RB X12 engine that I'm pretty sure needs a new p/s/r set. I'm pretty sure I read the same set from the V12 will fit, but I wasn't sure. Also, what would be the comparable novarossi set for that block? I haven't had much luck finding the RB set so far.
spenzalii is offline
Old 04-07-2008 | 02:31 PM
  #96
Originally Posted by spenzalii
Hey guys.
spenzalii,
We have both the Rody version and stock version in stock.
Have CWhit or your local dealer call us.
Jamie Corrado is offline
Old 04-07-2008 | 06:32 PM
  #97
spenzalii's Avatar
Jamie,
I was JUST checking Chris' message on this. Since it's for my brother (and he's not paying anything) I'm leaning toward the stock set. Then again, the price of either will decide what I'll get and do with the motor in the end.
Old 04-07-2008 | 06:41 PM
  #98
NitroWD's Avatar
ok thanks... now i'm having issues of the engine not able to hold idle...
the engine will simply stall/die upon the slightest impact. tried increasing the idle screw but still same...
can low/no compression cause this?
thanks...
NitroWD is offline
Old 04-09-2008 | 07:13 AM
  #99
All right well I have been searching for a bit now for more power and have cycled thru many companys engines. RB comes highly recommended so I have picked up a R3 .12 for my NT1. Now I live in Denver, Co. so the air is pretty thin up here. My question is what pipe/manifold combo is best? I heard the 2604 works very well. Also I run 30% Werks fuel what shimming should I be at for altitude and optimal preformance and power. Lastly in what temp range to these engines run in? I want to make sure I get the most out of my engine since the competition is pretty fierce up here. Thanks in advance and look forward to finally fullfilling my need for power.
Gitsum is offline
Old 04-14-2008 | 06:21 PM
  #100
teamgp's Avatar
Thanks Jamie for all the tips, help and support at the 2008 US Open Sedan Champs! Power was never a problem with the R3.
Still feeling bad for u know what though.
teamgp is offline
Old 04-15-2008 | 09:21 AM
  #101
kitracer's Avatar
thanks...
yes to your questions
try look at your throttle link. Brake for 2 sec to see if the engine will stall.
kitracer is offline
Old 04-16-2008 | 07:39 AM
  #102
Guy,
This is what I am here for, support! I am an open book, and whatever knowledge I have I am more than glad to pass off. It was fun pitting with you and Vincent and the rest of the 301 boys. See you guys this weekend.
Don't sweat the other thing, even though I am inside. LOL
Just kidding racing is racing and occasionally things like that happen. We both handled it in style. After all you are my Teammate and I was glad to see you advance regardless of the circumstances.
Old 04-16-2008 | 08:14 AM
  #103
teamgp's Avatar
Originally Posted by Jamie Corrado
Guy,
Now its time to git-r-done at 301!!!
teamgp is offline
Old 04-16-2008 | 08:20 AM
  #104
THeGame's Avatar
Guy did you show Jamie some guylove ? Are you ready for this weekend ?
THeGame is offline
Old 04-16-2008 | 09:35 AM
  #105
teamgp's Avatar
Ready freddy...
teamgp is offline
