Like Tree6Likes
RB Concept Engine Thread
Old 07-23-2008 | 09:57 AM
  #181
dead1dave's Avatar
no not the tank ...........my backup motors run just fine .
dead1dave is offline
Old 07-23-2008 | 12:23 PM
  #182
Paulie Bee's Avatar
Default Anyone have Xenon or Xenon R Cooling heads for sale?
WANTED! Does anyone have Xenon or Xenon R Cooling heads for sale? Please pm me if you do so we can discuss. Thanks....Paulie Bee
Paulie Bee is offline
Old 07-23-2008 | 10:01 PM
  #183
ToysRUsKid's Avatar
Looking for that new RB R3RC. Does anyone know where I can get one and what header/exhaust should go with it?
ToysRUsKid is offline
Old 07-24-2008 | 04:28 AM
  #184
ToysRUsKid,
The R3RC was just released to the public and should be hitting shops soon. We mainly run the 2604 in-line set that comes with a short header.
Jamie Corrado is offline
Old 07-24-2008 | 04:52 AM
  #185
1fastdude's Avatar
Does the Alpha engine use a Sirio or NovaRossi glow plug?
1fastdude is offline
Old 07-24-2008 | 05:49 AM
  #186
Paul - think I've got a loose one kicking around, will try to remember and look tonight
Rick Davis is offline
Old 07-24-2008 | 05:50 AM
  #187
Old 07-24-2008 | 06:10 AM
  #188
Eli,
Check your PM box.
Old 07-25-2008 | 10:00 AM
  #189
Paulie Bee's Avatar
please let me know...i appreciate it....paulie
Old 07-25-2008 | 10:41 AM
  #190
Looked in my parts box and there is a virgin Xenon R head - almost looks wrong, should i go rub it against my driveway?? - LOL Are you attending the GLC? if yes I'll just bring it along.
Old 07-26-2008 | 05:53 AM
  #191
Paulie Bee's Avatar
Hey Rick:
LOLOLOL Are you sure she is a virgin?...They all say that...LOL.
I will definately be attending the GLC. I really appreciate you looking out for me. My cell is 917-569-9091. Thanks again Rick. See you in Toledo!
Go RB.
Old 07-28-2008 | 06:06 AM
  #192
dead1dave's Avatar
I have a quick question for you tuner guys .............I am now really close to getting this C6 tuned in that I posted I was struggling with a while back.
If after a full throttle run down the straight away the idle "hangs"after the throttle is closed it is "what" on the low end ....rich or lean ? My settings are 3.5 on top and 5.5 on the LSN with the carb set at .8 mm throttle opening .Runs decent and doesn't stall but you can tell the tune is off .
I have leaned out the LSN before and then turned the idle down but then it stalls now and then . Simple right ? Just raise the idle ........well then the rpm "hangs" again ...................have I not gone lean enough yet ? I am running 20% sidewinder with a RB6 plug . Thanks for the help guys !
Old 07-28-2008 | 07:40 AM
  #193
Sounds like you have to richen up the bottom end a bit more.
.8 for idle opening is only a general number, don't hold to this. You should adjust as needed.
Old 07-28-2008 | 07:54 AM
  #194
dead1dave's Avatar
I figure .8 was a good starting point at least ....................with tuning these motors generally have you mostly seen the Idle tuned up then ? once the bottom end is set right ?
I had it set at almost 6 turns out for the one qualifier I was in but the low end throttle response was terrible ................BUT IT DID NOT HANG THE IDLE ........only thing is I then had to lean the top out because the thing was a dog all the way around the track ...............I didn't leave it that way because I thought I was going backwards with the needles . I this right ? Thanks so much for your quick response .
Old 07-28-2008 | 11:05 AM
  #195
wingracer's Avatar
If it is running really good except for the idle being high at the end of a straight then you a very close on the tune. Either richen up the bottom a bit or if it stays high for a while back off on the idle a touch. It may run a touch rich when cold like this but should lean out and be good after a few minutes of warm-up.
wingracer is offline
