Like Tree6Likes
RB Concept Engine Thread
Old 07-28-2008 | 01:50 PM
  #196
what is the actual head clearance of RB R3?
I measured the head clearance with the stock silver .3mm shim on, using the solder trick and I found it to be .5mm !!!!
I am running the engine with 16% nitro fuel.
Isnt ,5mm head clearance high for 16% nitro or have I messed up somewhere on my measurement?
sllo is offline
Old 07-28-2008 | 02:38 PM
  #197
We actually measure in inches not mm.
I myself only run 16% nitro content and have always used the .3 shim provided. You will be fine. Trust me.
Jamie Corrado is offline
Old 07-28-2008 | 09:36 PM
  #198
stefan's Avatar
It depends a bit on how high you are compared to sea level.
At sea level .5mm is ok for a 12 engine. At 550 m we run .45mm clearance (not shims)
stefan is offline
Old 07-28-2008 | 09:37 PM
  #199
stefan's Avatar
Shush!! No need to make everybody aware how backwards y'all are
stefan is offline
Old 07-28-2008 | 11:43 PM
  #200
I thought actual head clearance for .12 engines at sea level for various nitro % fuels was as this:
16% nitro .36mm - .4mm
20% nitro .4mm - .5mm
25% nitro .5mm - .6mm
30% nitro .6mm - .65mm
so for 16% nitro, that I am using, .5mm is kind of high.
Wouldnt someone gain more torque if .36mm-.4mm actual head clearance is used, instead of the factory .5mm clearance?
sllo is offline
Old 07-29-2008 | 03:55 AM
  #201
Old 07-29-2008 | 07:24 AM
  #202
Not to worry - some of even have calculators to go back and forth
Rick Davis is offline
Old 08-04-2008 | 08:16 PM
  #203
ToysRUsKid's Avatar
not so patiently waiting for that R3RC...
ToysRUsKid is offline
Old 08-05-2008 | 10:56 AM
  #204
Who did you order the engine from?
Old 08-05-2008 | 11:00 AM
  #205
wingracer's Avatar
Hopefully not the same person I just ordered from
Hehehe, get back to work dude.
wingracer is offline
Old 08-05-2008 | 11:03 AM
  #206
ToysRUsKid's Avatar
Didn't, no one has it listed, don't know where to order from. I can only find the original R3.
Old 08-05-2008 | 11:04 AM
  #207
ToysRUsKid's Avatar
Oh, and I'm waiting patiently for a response...
Old 08-05-2008 | 11:07 AM
  #208
wingracer's Avatar
Try calling around. Some people are pretty slow on updating their sites. Hopefully Jamie can tell us who he has shipped to.
Old 08-05-2008 | 11:58 AM
  #209
ToysRUsKid's Avatar
I called three places that I order from regularly and they don't have it.
Old 08-05-2008 | 12:02 PM
  #210
Have you tried:
http://www.murnanmodified.com/index.php
and
http://gasrccar.com/
Baedarlboo is offline
