Like Tree2Likes
Go-Tech Engines Thread
Old 10-17-2010 | 06:56 PM
  #12421
deadmancourt's Avatar
Originally Posted by quixoticboi
Sorry. My original post ended up being something entirely different... :/
the problem is you need the TRAXASS style crank!..and Go ONLY makes the SG style crank....so none of the go's will not work....i was trying to get 1 setup for a buddy but i could not get a TRAXASS style crank to run in a GO....
deadmancourt is offline
Old 10-17-2010 | 07:35 PM
  #12422
What if I use this:
http://www3.towerhobbies.com/cgi-bin/WTI0001P?&I=LXJF69
You can see what this guy does here:
http://www.misbehavin-rc.com/pit-lan...motor-swap.asp
quixoticboi is offline
Old 10-17-2010 | 07:55 PM
  #12423
22Racer's Avatar
I have a new rotostart backplate for a .25 Go, you need the .25 sport motor with the drive pin in the crank. Go Usa had some a few months ago.
Rex
22Racer is offline
Old 10-17-2010 | 07:58 PM
  #12424
22Racer's Avatar
Not sure if the one I have looks just like this but this is it.
http://www.go-engine.com/go_engine-2.htm
Rex
22Racer is offline
Old 10-17-2010 | 08:09 PM
  #12425
those wont work either!...the problem is the crank...it needs to have a slot for a C clip at the clutch end...and the only adapter is for a fully threaded crank...which Go does not make....i already tried this...i wanted to get 1 running for my buddy to go bash around with
Old 10-17-2010 | 10:40 PM
  #12426
Why can't I just cut from the threaded part here and add the clutch adapter mentioned above?
Old 10-18-2010 | 09:37 AM
  #12427
guntek18's Avatar
guys,
I just got my hands on a R21 3-port w/ novarossi carb.
I own (3) d8t truggys.
should i bother, what will this motor be good for????
guntek18 is offline
Old 10-18-2010 | 11:39 AM
  #12428
nitroexpress's Avatar
Originally Posted by guntek18
guys,
Three port would work on a buggy, but truggy not so good. Just for messing around it would work. Five port is preferred for a truggy.
nitroexpress is offline
Old 10-18-2010 | 12:17 PM
  #12429
jwm2's Avatar
3 port works great in a truggy. It has as much if not more bottom end than a 5 port. 7 port works great in a buggy. The 5 port is recommended in a truggy, but the 3 port works great as well.
I'm running a 3 port in my truggy and a 7 port in my buggy. I have one older 5 port and a new gxr 5 port i'm piecing together right now for backup engines.
jwm2 is offline
Old 10-18-2010 | 07:25 PM
  #12430
juggaloracer198's Avatar
anyone run at rev in socal??
juggaloracer198 is offline
Old 10-18-2010 | 07:46 PM
  #12431
Talking
I LOVE MY GX5R!!!!!!!!!!!!!!!!!!
Old 10-18-2010 | 09:25 PM
  #12432
jwm2's Avatar
I'm in need of a gx-5r tin coated crankshaft. If anyone knows where i can get one let me know. I've been bidding on ebay but have yet to win one. I'd like to pay about $30 if possible.
jwm2 is offline
Old 10-18-2010 | 09:36 PM
  #12433
doubt it!...thats less than the DEALER cost!...
Old 10-18-2010 | 09:45 PM
  #12434
22Racer's Avatar
I have a new one for a Mg66, it is the same except for less weight on the counterbalance. Not really where I would remove weight on a motor but it should work ok. $45.00 shipped.
Rex
22Racer is offline
Old 10-18-2010 | 09:49 PM
  #12435
Rex
how come i get YELLED @ when i try and PUSH my engines!.....you arent even a GO dealer anymore!.....you straight up PM'D me and told me i am TOO PUSHY.... i see you EVERYTIME someone wants to buy something
