Like Tree2Likes
Go-Tech Engines Thread
Old 05-10-2010 | 12:35 AM
  #10651
MassiveMods's Avatar
Originally Posted by bigmatt
mark, what is acceptable pipe temps? I am having trouble with my mg-66. I know about the shim stacks, and melting bodies.but what would you rec for clutch springs? It's the initial snap. almost like rich for second then wild ass ride.I am using answer clutch system with the 1.0 spings,go-tec 2072 pipe,30% byrons gen2 nitro. I will be going to the Amain 30% nitro from our U.S. distributor after I finish off my 1.5 gallons. I tried the amain25% nitro. what I like about it is how clean it burns. Inside of engine was perfectly clean. I am really wondering knowing what I have learned from this site and yours,if 20% nitro is the way to go. I know there is all sorts of things that go to pipe temps,but if you could point me in the right direction It would be appreciated.
BM
Acceptable pipe temps ? Have no idea , Hot enough to burn yoru hand
Check the inside recioever collett of your fly wheel , it may be worn and slipping , check the collet too , if it has scoring on it thats probably where its lagging .. The MG has plenty of instant snap.
If you run the 30 % A Main be sure to run 0.6 shims total. 7 mm restrictor
Run 1.1 springs. Answer rc shoes , 13 or 14 tooth depending ..
M
MassiveMods is offline
Old 05-10-2010 | 01:21 PM
  #10652
psychoracing's Avatar
Originally Posted by bobbyblaze
this weekend i break in my GX7R and tuned it alittle and im very well pleased...i will be buying another one for my truggy
hey , bobbyblaze for your truggy try the gx-5r with the 2072 pipe . thats what im running in my 2.0 truggy and its awsome...
psychoracing is offline
Old 05-12-2010 | 06:33 AM
  #10653
Default Tuning video
Hi, can Grizz or Massive Mods please make a short tuning video an put up on Youtube?
Covering how to tune both the long and short needle carbs, what to look/see/hear for, common mistakes etc etc.
This would be hundred times better for me than just reading about it.
Thanks.
Frode
Tigergutt is offline
Old 05-12-2010 | 07:34 AM
  #10654
Smile
What a great idea, go on you know you want too.
kevinjh is offline
Old 05-12-2010 | 08:33 AM
  #10655
MAGPIE-121's Avatar
lol & the production crew would enjoy the break from midget porn !!!!
MAGPIE-121 is offline
Old 05-12-2010 | 09:04 AM
  #10656
zonda's Avatar
Thanks.
Frode
+1
would be really helpful
zonda is offline
Old 05-12-2010 | 09:44 AM
  #10657
Gizmatron's Avatar
combine the two...naked midget tuning tips
Gizmatron is offline
Old 05-12-2010 | 09:58 AM
  #10658
MAGPIE-121's Avatar
lol, don't encourage them, it'll be a little blown production !
Old 05-12-2010 | 02:50 PM
  #10659
grizz1's Avatar
Sounds like Massive is far better equipped for the job than me (hmm, that didn't sound quite right did it ).
Would be a cool thing to have on vid. I think something like that should really come from Massive, after all, he is the Guru of the GO's. Especially seeing as he is involved in R&D and design on these motors. Sorry Mark, looks like I just dropped some extra work in your lap buddy
grizz1 is offline
Old 05-12-2010 | 03:21 PM
  #10660
bigmatt's Avatar
I need some one here in the U.S. that is a dealer to get me 4 of the or-0025 orings!!!!!!!!!!!!!!!!:ma d:
bigmatt is offline
Old 05-12-2010 | 03:59 PM
  #10661
Merciless's Avatar
Thanks.
Frode
Also have to say I think this is a VERY good idea
Rod
Merciless is offline
Old 05-12-2010 | 05:10 PM
  #10662
PM sent Matt,
rageworks is offline
Old 05-12-2010 | 05:27 PM
  #10663
bigmatt's Avatar
Originally Posted by rageworks
PM sent Matt,
replied,racer 22 say's they may have changed the part# to or-0023. these are seals for the gen 5.5 hsn/lsn. the carb has the red go-tec logo on the front. I have done the fuel tubing trick that grizz taught me but want the correct seals. I had mark from mmods send me the last group of seals. the package had some thin ones [they worked] and thicker ones. I put those one my 808 shocks to keep form bottoming out. thanks for the help guys.
bigmatt is offline
Old 05-12-2010 | 05:44 PM
  #10664
It's just like it was when Russel ran the show Matt.
If Amain doesn't have it listed, none of the other dealers
are set up with a web site that you can order directly
from. There is no list of dealers and there phone numbers
or web addresses on the go-engines-usa.com site.
So it's a crap shoot if the dealer you get ahold of doesn't
have what you need in stock. He has to have the parts
shipped from GOUSA to him and then to you. If GOUSA
doesn't have the item in stock, then it's an extra to weeks
to two months wait. Thats how I ended up owning so many
GO engines. Hell, one out of five should be up and running
while waiting for the delivery man to show up.
No, no I don't have the part you need, but I can give you a
great deal on a new engine, said the dealer. S.O.S. as before.
Old 05-12-2010 | 05:50 PM
  #10665
Matt I have ten of the older style or0023 o-rings.
E-mail me your address and i'll give you four of them
if you want. Good enough to keep you going for now.
