Like Tree2Likes
Go-Tech Engines Thread
Old 05-09-2010 | 01:43 PM
  #10636
kael's Avatar
Originally Posted by 22Racer
No problem switching from Byrons to Sidewinder, We run Byrons but used to run Sidewinder with no problems. Depending on oil % you may have to retune and hour or 2 but thats it.
Rex
Thanks Rex. Curious, why did you switch Sidewinder->Byron's?
Maybe I'll try Sidewinder of a couple of tanks, hopefully no issue going back to Byron's.
kael is offline
Old 05-09-2010 | 01:45 PM
  #10637
BSchorr's Avatar
R/C Tech Elite Member
I run the nitro series with Kendall and Rex. Most people use Byrons because there is a few people that order in cases of Byrons to sell to the people in the nitro series. I think there is only a few people that run Dynamite Blue Thunder, because they are sponsored by Dynamite/Horizon hobby.
Byrons Race Blend 2 30% is the $hit!
BSchorr is offline
Old 05-09-2010 | 02:45 PM
  #10638
grizz1's Avatar
Originally Posted by grubby
WELL I TOOK EVERYONES ADVICE AND TUNED IT BY PROFORMANCE AND RAN MY .28 6 PORT AT THE OFNA RACE THIS WEEKEND AND IT DID GOOD FOR A LITTLE BUT RUNNING 300 WITH PLENTY OF SMOKE AND THE SECOND HEAT RACE THE ENGINE WENT PLOP. NO MORE ENGINE. LOST ALL COMP. ONLY HAD ABOUT 1/2 TO 3/4 OF A GALLON OF FULE IN IT AND SO I GUESS I WILL THROW THAT ONE IN THE BOOKS. KINDA MAKES ME MAD THAT I DID WHAT EVERYBODY SAID TO DO ON HERE AND FROM GO TECK AND WITH SO LITTLE FULE ON IT SHE LOST ALL COMP.
ANYBODY CARE TO TRY TO ANSWER THAE QUESTION ON WHY IT DID THAT
OR JUST MAINLY THE ONES THAT TOLD ME TO RUN IT LIKE THAT
Hey grubby, really sorry to hear about your engine, but I don't believe it's anything to do with the info you were given on here. Everyone on here is trying to be helpful, not give out bad info.
To be honest putting a race tune on your motor after only a couple of litres through it is probably not the best practice. It would have still been pretty tight at that stage.
As previously mentioned, if your using good fuel and blowing good smoke with a temp of 300, that doesn't really add up. I would get your temp gun checked out. That's one of the big problems with tuning to temps. Accuracy of heat guns is very dubious (and that's being kind). If you really want to keep an eye on temps, use the good old spit test method. It is as accurate as anything. Ideally the spit you wipe on the head should evapourate away completely in around 4 - 5 secs. If it's sizzling and bubbling the spit straight off the head in a second or so then it's too hot. That's really as much as you want to know about temps.
If your motor was blowing good smoke (at all times) and you still killed the motor, you have other problems (loose head bolts, air leak, but quite possibly tuning issues).
Originally Posted by harleyrules
Hi guys.
This is a serious question so please don´t start any bashing.
I´m considering trying the GO engines and I have been using a OS V-Spec and I´m satisfied with it but I would like a more mellow/controllable bottom.
It hits like hell on the bottom.
I´ve tried a couple of my friends Novarossi +4 engines with the exact same car/setup as my car including the same clutch-setup and damn it´s a nice engine... Smooooth and fast with good runtime.
Should I try the GX-3R, GX-5R or GX-7R if I would like an engine to perform like the +4?
Thanks for your time.
Hi harleyrules. The closest to the +4 out of those motors would be the GX-7R. It is softer on the bottom than the 5R, but has brilliant top end that you won't really appreciate until you run one These things are really strong from mid to top.
The 3R is very smooth, but does not have the top end of the 7R
Having said all that, the ultimate GO based buggy motor is the Massive Mods MG66 which is now available in the USA. It is a modded 6 Port motor that is smooth right through the rev range with incredible mid and top end (like the 7R on steroids).
The MG66 would be my first choice, followed by the GX-7R. I run all three motors at different tracks from time to time, so the comparison I have given is pretty accurate IMO. Cheers
grizz1 is offline
Old 05-09-2010 | 03:32 PM
  #10639
22Racer's Avatar
Just like Ben said the Byrons is easier to get, it's made more local, only about 3 hours from me and they sponsor our Mn Nitro Series!
Rex
22Racer is offline
Old 05-09-2010 | 03:37 PM
  #10640
22Racer's Avatar
That is too bad about your engine. Send it to me and if it is fixable I will fix it for free, just pay for the rod or any parts it may need. I will also tell you if your carb was tuned well.
Where did you buy it from, they could maybe get it warrantied?
Rex
22Racer is offline
Old 05-09-2010 | 05:11 PM
  #10641
psychoracing's Avatar
Hi guys.
get thet gx-7r with the 2072 go pipe.. and if u r in to modding give rick a ring at rbmods..
psychoracing is offline
Old 05-09-2010 | 07:51 PM
  #10642
bobbyblaze's Avatar
this weekend i break in my GX7R and tuned it alittle and im very well pleased...i will be buying another one for my truggy
bobbyblaze is offline
Old 05-09-2010 | 08:22 PM
  #10643
grizz1's Avatar
Glad you like the product. The 7R in a buggy is very nice
Have you thought of a GX-5R for your truggy ? More bottom end than the 7, but not quite as much top. Guess it depends on how open or tight your track is. Guys here run both motors in truggy, but the 5R is the more popular choice.
grizz1 is offline
Old 05-09-2010 | 08:48 PM
  #10644
22Racer's Avatar
Defiantely try a 5 port for the truggy.
Rex
22Racer is offline
Old 05-09-2010 | 08:56 PM
  #10645
bigmatt's Avatar
Rex
or the mg-66 you have for sale. It will push a truggy around very well.
bigmatt is offline
Old 05-09-2010 | 09:14 PM
  #10646
Hey i ripped my carb boot. Does anyone know what boot to get off amain? They dont have a go one. i was thinking that one. Thank you.
http://www.amainhobbies.com/product_...etor-Dust-Boot
rcdude236 is offline
Old 05-09-2010 | 09:16 PM
  #10647
MAGPIE-121's Avatar
Hi guys.
+1 what grizz said on the MG66, smoothest motor on the market, go forward not sideways, faster lap times & longer run times.
you won't be disappointed.
MAGPIE-121 is offline
Old 05-09-2010 | 09:37 PM
  #10648
zJatoRad's Avatar
Hey guys if you're interested in GO stuff, I'm selling all of my GO products so check it out.
http://www.rctech.net/forum/r-c-item...ml#post7383884
zJatoRad is offline
Old 05-09-2010 | 09:38 PM
  #10649
Thanks for your help, GX-7R is the one I´m gonna try
harleyrules is offline
Old 05-09-2010 | 09:53 PM
  #10650
grizz1's Avatar
You won't be disapointed Come back and tell us your thoughts on the 7R after you have a gallon or so through it.
grizz1 is offline
