Like Tree2Likes
Go-Tech Engines Thread
Old 02-10-2010 | 07:27 PM
  #9961
MAGPIE-121's Avatar
Originally Posted by shanef
weren't the old ones working and you had to up the dosage?
what ever happened to patient confidentiality !!!!!!!! bloody doctors
MAGPIE-121 is offline
Old 02-10-2010 | 07:29 PM
  #9962
MAGPIE-121's Avatar
shane how is that motor going ?
Old 02-10-2010 | 08:26 PM
  #9963
22Racer's Avatar
Originally Posted by meno222
do you guys know if a p/s from a 3p race fit n 3p sport engine case. thanks
Yes it will fit fine, all Go .21's will interchange. The sport case has a 25mm bearing instead of the 25.4mm in the race models. Also the case on the sport does not have the cuts milled in it above the rear bearing, may be a slight decrease in power. A bigger factor may be the case on exhaust port might not be tall enough on the sport case. It will run just fine, performance may be a little less though.
Rex
22Racer is offline
Old 02-10-2010 | 11:08 PM
  #9964
Blackie001's Avatar
Originally Posted by MAGPIE-121
lol i've got new arthritus meds & viagra
LMAO, Nice!
Blackie001 is offline
Old 02-11-2010 | 12:49 AM
  #9965
shanef's Avatar
It arrived back on tuesday after some massive mods tlc (mark replaced both bearings, p/r/s, crank and gave it a rough tune).
Went and got a complete clutch setup for it today so i now have 2 engines complete with clutch's on so if anything happens to either of them on race day its only a 5min job instead of 30 to change them over.
Won't be able to get a tune on it before sunday so i'll race with the alpha and hopefully get a tune on the go sometime nextweek.
shanef is offline
Old 02-11-2010 | 05:57 PM
  #9966
MassiveMods's Avatar
A MAin Fuels will be avail at MOTORAMA
Any questions please don't hesitate !
Cheers MM
MassiveMods is offline
Old 02-12-2010 | 08:37 AM
  #9967
su3zero's Avatar
thank you all guys.
thanks lowlife88.. for the help
today Go GX-5R go "in Stock" at amain hobbies and as fast as i can, i got mine!
su3zero is offline
Old 02-12-2010 | 10:46 AM
  #9968
Ruune's Avatar
Originally Posted by su3zero
thank you all guys.
Yes, amain should be well stocked for a bit. I did just receive an order for a few parts, etc.
Also, moto has a large shipment of parts on the way.
Ruune is offline
Old 02-12-2010 | 10:50 AM
  #9969
su3zero's Avatar
now i need to choose a good pipe... but will not buy now...
what pipe do i have to use?
i'll race 90% of time at this track:
thanks again
su3zero is offline
Old 02-12-2010 | 10:52 AM
  #9970
Ruune's Avatar
EFRA 2072 on the 5-port will be DIALED.
Ruune is offline
Old 02-12-2010 | 12:22 PM
  #9971
rider313's Avatar
+1. thats a great combo. cant wait to get some more nitro threw mine/
rider313 is offline
Old 02-12-2010 | 05:40 PM
  #9972
mattwoodcraft's Avatar
the 2072 will provide the best overall performance for sure from start to finish
mattwoodcraft is offline
Old 02-13-2010 | 01:23 PM
  #9973
Madbrad's Avatar
im working on a Go tech 3R and need to replace the HSN and LSN gasket . I found this one but im not sure if it will work for both are the ydifferent ?
Link
Madbrad is offline
Old 02-13-2010 | 02:14 PM
  #9974
MAGPIE-121's Avatar
they will get u going, or these will last longer : -http://www.massivemods.com.au/produc...roducts_id=207
Old 02-13-2010 | 03:21 PM
  #9975
bigmatt's Avatar
cut some silicon fuel line to the thickness of the o-ring,and install. Works perfect. And buy the ones from massive mods. They last forever.
bigmatt is offline
