Like Tree2Likes
Go-Tech Engines Thread
Old 12-05-2009 | 10:41 AM
  #9466
grizz1's Avatar
If your running 25 - 30% nitro you might like to try a cooler plug. The P3 is an ultra hot plug. Try the O'Donnell 77T (hot) or 97T (med), or the new GO T4 (med hot).
With high nitro content a cooler plug can work better.
grizz1 is offline
Old 12-05-2009 | 02:39 PM
  #9467
MassiveMods's Avatar
Howdy All
FYI
The new HSN needle is being sent to various distributors to see the difference in tuning. The new HSN needle is designed to have a broader sweep which will make it less sensitive.
Re Carb
id be opting for a new GX carb as opposed to rebuilding your existing one , especially if it has the wiggle. OR just use the RB or OS carb you have .
M
MassiveMods is offline
Old 12-05-2009 | 07:41 PM
  #9468
mattwoodcraft's Avatar
i would like to get these t4 plugs i think at times the plugs i run are a bit to hot ..
mattwoodcraft is offline
Old 12-05-2009 | 08:10 PM
  #9469
Default go 25 what anice engine!!!
just finished breaking the go 25 in.. it has tons of power
losirich is offline
Old 12-05-2009 | 11:48 PM
  #9470
grizz1's Avatar
Originally Posted by MassiveMods
Howdy All
FYI
Re Carb
M
Hiya Massive. Just to confirm the new HSN needle is for the MG66 only - yes ?
It is a tad touchy on the top end I must admit
grizz1 is offline
Old 12-06-2009 | 01:29 AM
  #9471
ochitone's Avatar
Originally Posted by Ruune
No I havent heard from him yet.
Trey,
Please give him a call. I am not sure what the problem is, but he told me he was waiting on you to contact him, if I understood correctly. Anyway.
Matt Anderson @ Anderson R/C
336-476-6917
M-F 9:00-7:00
S 9:00-6:00
Sun closed
ochitone is offline
Old 12-06-2009 | 02:10 AM
  #9472
grizz i think its on the gx line aswell mate
Old 12-06-2009 | 04:48 AM
  #9473
nitroexpress's Avatar
Anyone try the new Byron's 40% nitro yet?
nitroexpress is offline
Old 12-06-2009 | 06:41 AM
  #9474
i didnt relize you could get this fuel with a high nitro content to race with
Old 12-06-2009 | 06:45 AM
  #9475
Gizmatron's Avatar
why would you want to..???????
Gizmatron is offline
Old 12-06-2009 | 06:48 AM
  #9476
Gizmatron's Avatar
Howdy All
FYI
M
mark..you making these available for general sale? If so put one aside for me and I'll put in an order just after Christmas for a bunch of stuff...
ps got my new diff housings and OH! what a difference..had to practically hammer the bearings in and remove 3 of 4 diff shims as well..guess the tolerances were improved as well as the materials..this should stop the MG66 destroying drive pinions anyway.....
Old 12-06-2009 | 01:42 PM
  #9477
No, the new needle i designed will be for the whole Go GX range and MG66 . They are retrofittable to gen 5 range as well. You can simply remove the original HSN needle and put the new one in . The MG and GX carb are the same except for LSN options . The MG carbs all come with long LSN needle. As previously stated once you set your LSN you rarely have to touch it again, you only have to do small changes on the HSN for day to day enviroment.
We are waiting on stock so keep an eye on the site.
www.massivemods.com
CHEERS MM
Old 12-06-2009 | 01:44 PM
  #9478
Yes they will be avail as an upgrade. poor pinion gears
Old 12-07-2009 | 05:21 AM
  #9479
Gizmatron's Avatar
Thank you for that very sincere sympathy..NOT well at least I found the problem before the new years racing starts..the harder compound diff housing is streets tighter tolerances than the old one I fitted...and as if the rain isn't enough we just heard we will probably be losing all our track parking and eating area to bloody solar panels as the village have decided to rent the rest of the land to the electric board...sigh..maybe if they dig out enough foundations we can fill in the dip right in front of the circuit and have the parking there..
even worse the aeromedelisme club from the next town have lost their land next to the aerodrome so are looking to sneak into the village too but federation rules forbid opening any R/C club within 5 miles of an existing one to avoid obvious frequency clashes..so first they suggest we should all go spektrum 2.4ghz so we don't get problems(at our own expense naturally) and today we found out they have been secretly proposing we merge the two clubs and move to a new site they have in mind at some disused quarry..Just what I fancied was dismantling 3 years work and moving the track to a site less convenient and further from home..I think F.O.A.D is my favored response.......
sorry off topic but I needed a rant
Old 12-07-2009 | 06:32 AM
  #9480
man that sucks a big one hope all works for you in the end
