Like Tree2Likes
Go-Tech Engines Thread
Old 12-02-2009 | 04:58 PM
  #9421
mattwoodcraft's Avatar
whats the problem mate ?
mattwoodcraft is offline
Old 12-02-2009 | 05:47 PM
  #9422
bigmatt's Avatar
Originally Posted by LOSIRACER77
I need a go tech racer that knows the older motors, cause I got a older motor and I need help!!!!!!! Tunning,I thnk I might need a carb, I don't know please call me At 270 627 6705, please
why would any one call long distance? And wasn't there some scam going around with the 209 area code awhile back? Any way what's your problem with the engine? There are a number of people on this thread that could fix your engine by what you can describe.
bigmatt is offline
Old 12-02-2009 | 06:40 PM
  #9423
LOSIRACER77, I see by the area code that you are
located somewhere in western Kentucky. If you can't
find anyone local to help you out, post whats going
on with with your engine on this thread. Getting input
from all the guys on here should get your engine running
properly again.
rageworks is offline
Old 12-02-2009 | 07:11 PM
  #9424
Guest
Default The problem child
Well the 5 port is an old block it doesn't tune like other go techs I got, it has a mind if it own, I have put new bearings in it, gaskets, the damn thang will not hold a tune, but when it's right it's fast!! The needles have to be screwed in so far down in the carb. It seems like 1 hour of a turn does alot!! The carb slide is notchy and wiggles, I am thinking that I need a carb. I got alot of RB concept carbs and I got some OS v-spec carbs. Which carb should I use???
LOSIRACER77 is offline
Old 12-02-2009 | 08:48 PM
  #9425
zJatoRad's Avatar
Either carb will drop right in, I would go with the OS carb though. Have you checked the Go carb needle o-rings.
zJatoRad is offline
Old 12-02-2009 | 09:48 PM
  #9426
Ruune's Avatar
you should try replacing the seals with the new nitrile ones. I have these in stock... have your local shop contact me, or ask any of the dealers on here and we can get you fixed up!
Ruune is offline
Old 12-02-2009 | 09:51 PM
  #9427
Ruune's Avatar
Default PREVIEW!!!
Just wanted to share with you guys, some of the progress that's going on behind the scenes at www.go-engine-usa.com.
We're getting close, but there are still a few things to do, plus some banners and content to add, but here's a sneak peek...
Ruune is offline
Old 12-03-2009 | 12:17 AM
  #9428
if you can not get hold of the new seals just use fuel tube this all i use now works and lasts for ever and holds just perfect
Old 12-03-2009 | 12:19 AM
  #9429
the new site is looking the good for sure mate
Old 12-03-2009 | 05:24 AM
  #9430
69mustangbjs's Avatar
new site is looking killer T, cant wait to surf it
69mustangbjs is offline
Old 12-03-2009 | 08:58 AM
  #9431
lowlife88's Avatar
Trey, site is lookin awsome!!! Your buggy cleaned up pretty good for the pics! LOL
lowlife88 is offline
Old 12-03-2009 | 09:26 AM
  #9432
Guest
Default Websit
I think that the pic should have been losi 2.0!!!!! Haha
Old 12-03-2009 | 01:22 PM
  #9433
Ruune's Avatar
um... it is a Losi 8ight 2.0.
Ruune is offline
Old 12-03-2009 | 05:35 PM
  #9434
22Racer's Avatar
I've heard some of the early Go's had a different taper on the needle's and one hour was a big adjustment. If you haven't put new o-rings in the high and low speed I would do that first.
Rex
22Racer is offline
Old 12-03-2009 | 05:42 PM
  #9435
on the new carbs to 1 hour seems to be a huge ajustment 1/2 only
