Like Tree2Likes
Go-Tech Engines Thread
Old 04-15-2009 | 06:44 PM
  #6391
mfrosty's Avatar
Originally Posted by ccumbe
Mfrosty is this the track that Middle River Hobbies opened? I am planning on going there Friday for some practice. I hear there are some other guys coming up from the south.
Yep that's the one. I'll be there Friday too.
mfrosty is offline
Old 04-16-2009 | 05:14 PM
  #6392
MassiveMods's Avatar
You can interchange the sleeves between the Pro engines in .21 class.
you cannot interchange them between Pro and Sport class engines.
you cannot change between Sport .25 and .28 and Pro .25 and .28 .. Crank case changes will hamper the gas flow between the RTR crank case and Pro crank case .. So it wont really give you the max change .
Hampering the gas flow can cause over heating problems.
Re Special RC, Please be aware that the Go Factory does not modify the engines , they are stock gen 4 and 5 engines. Note he does not have gen 5.5
which are being distributed to Authorised dealers only. He is stating that they are modified so he can sell into other peoples areas. but be aware that you do not get any warranty with the engine from Ebay . only an Authorised dealer can factory warrant an engine.
MM
MassiveMods is offline
Old 04-16-2009 | 05:35 PM
  #6393
bigmatt's Avatar
MM
mark I see you sell the 5.5 crank, do you sell the 5.5 engines? and I thought they were coming out with gen 6 engine.
bigmatt is offline
Old 04-16-2009 | 06:23 PM
  #6394
Yes we sell the 5.5 so does racefactor and other authorised dealers world wide. Please be informed that only the Go brand has these upgrades.
Gen 6 ... well you may see it in June or July this year .. All depends on testing but we will inform you when it is released..
M
Old 04-16-2009 | 06:29 PM
  #6395
mfrosty's Avatar
Mark, engine's AWESOME bro! Very happy with it. Almost have a gallon through it now. Running it in the ROAR Region 2 race on Saturday
mfrosty is offline
Old 04-17-2009 | 09:29 AM
  #6396
Hi I just bought a used 7 port (2 gals) and wanted to replace the rod, a-main only sells them for the 5 port, are they the same? Thanks for the help, looking forward to trying my first GO.
buglite62 is offline
Old 04-17-2009 | 11:05 AM
  #6397
zJatoRad's Avatar
all of the Go race and sport engines use the same connecting rod.
zJatoRad is offline
Old 04-17-2009 | 11:16 AM
  #6398
rearviewmirror's Avatar
Amain hasn't had a GO ROD in stock for months....
rearviewmirror is offline
Old 04-17-2009 | 11:29 AM
  #6399
bigmatt's Avatar
get a hold of mark at massive mods. they come from Australia but you will wait forever for Russ at race factor industries to do anything. also tell mark you would like the c clips and wrist pin.
bigmatt is offline
Old 04-17-2009 | 11:45 AM
  #6400
22Racer on this forum also has some for sale.
Old 04-17-2009 | 01:20 PM
  #6401
looper's Avatar
Originally Posted by 22Racer
When rebuilding the motor I take it apart and clean it, inspect bearings, inspect crank and rod for wear (i use a mic and a bore guage that measures to .0001 of an inch), and pinch the sleeve. It includes replacing rod or bearings but any parts are extra. I usually use Tko ceramic bearings, the rear is $22.95. Of course when I'm done I put it back together.
If I am just pinching the sleeve I will clean the top of the piston, I don't recommend a dremel and wire wheel!
I am going on vacation and won't be back until 1st of May so I won't be doing anything for 2 weeks.
Rex
pm sent, thanks
looper is offline
Old 04-17-2009 | 03:36 PM
  #6402
Not anymore the Pro Range of Go Engines have an updated rod in the 5.5 version. Some of the Gen 5 have them too.
regardless they can interchange as they both have 29.5 centre
Old 04-17-2009 | 03:37 PM
  #6403
UNREAL ! Fang it man ! hahah
Glad to hear its running great for you !
keep us posted and make sure you stay clear of netball posts and small animals
Old 04-17-2009 | 03:59 PM
  #6404
Squeakyz r/c's Avatar
Does anyone no how to get in touch with Russell from racefactor
Squeakyz r/c is offline
Old 04-17-2009 | 04:19 PM
  #6405
Thank you for all the reply's, Have a great weekend.
