Go-Tech Engines Thread
#5386
wick3dr00st3r
here is 3 port sport specs
Specifications:
Maximum power: 2.60 hp
RPM: 31,000 rpm
Practical RPM Range: 6,000 - 37,000 rpm
Bore: 16.26mm
Stroke: 16.80mm
Crankshaft: 14mm SG
Glow Plug Type: Standard
Exhaust Type: Rear
here is 3 port race specs
Maximum Power 2.6hp
R.P.M 37.000rpm
Practical Range 6.000/40.000rpm
Bore/Stroke 16.26mm/16.80mm
Ports 3+2
Crankshaft 14mm SG
Carburetor 8mm
Glow Plug Type Turbo
Exhaust Type Rear
you can put a turbo button on the sport engine but it wont make it like the race 3 port but will be close and runs just as good
i ran one with turbo button and the go black carb instead of stock sport and it ran awesome. for what you are wanting to stay reasonable on price you will like it . if you dont mind paying alittle more for a motor the race 3 port will be a rocket and is very powerful thnx will g
#5390
I would tend to stick to alloy shoes if you are racing, just for the wear factor.
We have a lot of jumps straight out of corners so I need the 1.1 springs to get a good launch. Most tracks might suit 1.0 springs and alloy shoes better.
Just experiment with clutch, pipe, springs and shoes until you find what works best for your driving style and the tracks you run.
#5391
Your buggy is probably alittle lighter than the 1 I will be running, I already planned on the 6.5mm restrictor from the start. I will start where I said and thn maybe try a mix like 2 alum and 1 carbon w/1.0 springs. I tried mixing before on truggy and had no luck with it. I will mostly be on med size tracks hard packed with some dust on the edges. I really dont want to go with alum if I dont have to. Whats the difference between teflon and carbon shoes? My chassis sponsor has both available and 2 styles of 7075 alum shoes but like I said I am going to try to not have to use the alum shoes unless I have to.
#5392
A turbo button should be enough you can feel a difference but not real drastic.
Rex
#5393
#5394
I am going to get a .28 sport also because I like to mod my own engines. Rex do you just open the ports up a little and polish the crank? I open up the fangs alittle + the ports but leave the EXHAUST port alone. Was thinking of trying some crank work, I have a few old ofna force .28's around here that I ported and they fly for a cheap engine.What kind of a apoxy do you use for the crank to fill in the ramp.
I only turn left !!!
#5395
Teflon "should" wear better, imo, teflon or carbon should only be used for mid to top end motors like the 7 port, it would help with a better take off as the tef/carb shoes engage later in the rev range because there lighter, with the 5 and 3 port, i'd stick to alloy with ether 1.0 or 1.1 springs as it has awesome bottom ( just to let you know i have run in my 5 port with this setup, with slicks on new bitumen and i can easily lose traction!!!
#5396
Malik, I don't know how the Casters will compare to Mugen but I ran the stand. alum. with 1.0 springs in my 3r and it was perfect. Used the standard carb restric. with an 086 and it was super linear. On my truggy I ran the mugen carbon shoes with 1.0 springs with a go 5 port. standard carb restric. with jp-2 and it was very smooth too. I was shocked how well the carbons wore with the 1.0 spring in a truggy.
with that said I would try the casters or get ahold of russell and try the vp pro shoes with 1.0 springs in buggy shouldn't be a problem.
#5397
i liked the teflon shoes with the 1.1's, not too much and just enough at the same time. the teflons look to wear better than the carbon's so i already ordered 3 sets of shoes and springs. they also seem to de-burr themselves regularly. the caster springs you need to trim about 5mm off the ends so they don't hit the clutchbell. i'll try them on the truggy soon but i don't think it will be enough, maybe good on a really loose track.
#5398
EB mods 5-port
Anyone hot one yet!
#5399
Best clutch combo for a 5pt is light weight alumn. shoes with .9 springs in buggy, smooths out the power and also gets better mileage. plus with alumn. shoes your clutch always grabs when you need it too. The Vp shoes are nice, they are light and come with all the springs, they are a soft alumn. though so they are not like themax life shoes, but they grab hard.
Also for anyone who says you can't race a 3 port sport engine, i have to proove you wrong, I ran one in a 2 hour endurance race and it ran fan. I raced it out and california (hesperia) and won buggy against P5's and other engines, it also the same engine I gave Will to run and he thought it was great, I think its a great engine for someone just looking for something to play around with and race occasionally. I do reccomend a turbo head button.
#5400
Were can I get vp-pro parts from a US dealer ?
thanks
thanks
