Like Tree2Likes
Go-Tech Engines Thread
Old 06-15-2008 | 07:08 PM
  #3166
Will undershimming cause the problems I have described?
Semple is offline
Old 06-15-2008 | 07:22 PM
  #3167
sachoppers's Avatar
ah..I see
well i installed the extra 1..20%break in ..but ill change to 30% when this gal. is done.
as for the new version...my crank case is black and the carb end is also black..not silver ...no sure if its the same for 5p and 7p.
sachoppers is offline
Old 06-15-2008 | 07:31 PM
  #3168
sachoppers's Avatar
Originally Posted by zJatoRad
he did warm up the engine but still, after a few mins of racing the lean bog issues would come up, and the engine is not even hot, immediately after he replaced the needle he said that there was a big change in the performance, ran the engine for 15 straight mins (1 refill) and not a single lean bog after the needle change.
Was this on a new engine?
also how did the needle (the problem 1) look?
Old 06-15-2008 | 07:39 PM
  #3169
mugenb46's Avatar
yes, detination, or predetination. even though these little basterds don't have a coil, they can fire before or after TDC, on our modified engines i like to run between 22 and 24 thou, with much more agressive timming we can end up with only one shim, but the engines that get sold are set to have a varience of between 22 and 24. you would be suprised how many new out of the box engines and i mean all brands not just one fire befor TDC or after. a pre or detinating motor will blow plugs and eat coils out of glow plugs, and a worn rod will also cause this detination and eratic running, so get some shims and do a bolt check and everything should be good, and also try a different brand if the others are not working out. I havn't had problems wiith OS but alot of people say some come dead even though there new. Odonnol plugs are also good.
mugenb46 is offline
Old 06-15-2008 | 07:41 PM
  #3170
mugenb46's Avatar
Originally Posted by sachoppers
ah..I see
yes that is the 08 engine, and if your running 20 for sure go to 30, when they have the correct shimms that is what tyhey are shimmed for is 30, the 3 5 and 7 all have the black case.
mugenb46 is offline
Old 06-15-2008 | 07:44 PM
  #3171
skeller's Avatar
Damn...like a friggin ninja!!! Swooped in out of the dark and posted before I could.
skeller is offline
Old 06-15-2008 | 07:46 PM
  #3172
mugenb46's Avatar
as for needles, the only one i change is the LS, you can run a NR LS or the old GO LSN.
mugenb46 is offline
Old 06-15-2008 | 07:48 PM
  #3173
sachoppers's Avatar
22-24...can i measure that putting all the shims together(even the silver 1)..and ck it with a dial caliper?
Old 06-15-2008 | 07:49 PM
  #3174
mugenb46's Avatar
correction, not sure if the NR fit's the GO carb, but i do use the GO LS often.
mugenb46 is offline
  #3175
skeller's Avatar
yes you can use a dial caliper.....ha ha I answered before ninja Brian!!!!!!!
That better?
skeller is offline
Old 06-15-2008 | 07:51 PM
  #3176
mugenb46's Avatar
but your not using it
mugenb46 is offline
Old 06-15-2008 | 07:53 PM
  #3177
skeller's Avatar
I answered a ??? before ninja Brian got to it......that's what I'm talkin' bout.
skeller is offline
Old 06-15-2008 | 07:58 PM
  #3178
skeller's Avatar
Somebody ask an engine question...let's see if I can answer right before Brian.
skeller is offline
  #3179
mugenb46's Avatar
I use a depth indicator, and measure the piston at TDC, and then the hight of the button, the space inbetween will give you your squish or deck hight, if you engine will roll over without getting stuck at TDC, you can do the solder test, this will get you in the ball park if you don't have depth indicators, it really alot faster only a bit less accurate, but it will get you close.
mugenb46 is offline
Old 06-15-2008 | 08:01 PM
  #3180
sachoppers's Avatar
Im liking the good info on this forum..gota love it. thx.
And i do have the tools to do that..so when its broke in..ill do just that
