Like Tree2Likes
Go-Tech Engines Thread
Old 06-06-2008 | 03:30 PM
  #3076
chim13's Avatar
just got my 0801 pipe today already on the buggy and i ran a tank with it sounds and runs great. I have it on the 7 port turbo. I also got my 3 port race today also. I was running the 7 port with a os 2050 and i thought that it ran great what kind of differences should i see with the 0801 pipe. Also wondering the biggest difference between the 3 port race and the 7 port turbo. Both of my engines are the 08 version. thanks guys.
chim13 is offline
Old 06-06-2008 | 03:33 PM
  #3077
well i ran the buggy some today ran like pooh and would lean bog. i know its not a tank issue because its done it in 3 different cars
so i was going to pull the carb but i figured why not try the novarossi low end needle which was recommended. welll it worked the engine runs really strong throughout the power band so my mysterious bog issues are gone
thanks to all the helped
cheesecake is offline
Old 06-06-2008 | 03:42 PM
  #3078
Vigilante212's Avatar
Bad oring on the needle perhaps?
Vigilante212 is offline
Old 06-06-2008 | 03:45 PM
  #3079
nope it was a bad needle for some odd reason some of the needles thin out too much and cause tuning nightmares
thats what i think it is
i checked the orings after i removed it and they look like new so i dont think that was it
Old 06-06-2008 | 03:50 PM
  #3080
Tree's Avatar
I have been having the same issues. I try to lean the HSN but it bogs when I pull the trigger to WOT. I richened the HSN back up and the bog went away. The engine is running really rich with a lot of smoke and unburned fuel coming out of the 086 pipe.
Where can I get the novarossi needles?
Tree is offline
Old 06-06-2008 | 03:52 PM
  #3081
i think amain has them also look into a replacement go needle i heard it was a very small batch with problems
Old 06-06-2008 | 03:56 PM
  #3082
Tree's Avatar
Do you think Russell at Race Factor Industries will replace the needles free of charge?
Tree is offline
Old 06-06-2008 | 03:58 PM
  #3083
send him a email. let him know what issues your having.
Old 06-06-2008 | 08:51 PM
  #3084
grizz1's Avatar
Hey cheese, glad to see you got it sorted bro Things like that can be really frustrating huh ??
I have been really lucky with my Go engines. Not one problem, which was just as well, as I am still fairly new at this game. Got a pretty good handle on tuning these little buggers now, but something like that would have really thrown me a curve ball
grizz1 is offline
Old 06-07-2008 | 08:08 PM
  #3085
what glow plug and pipe suggestions does everyone have for the .25. thinking of picking one up for my 5T. thanks!!!
nitro0619 is offline
Old 06-07-2008 | 09:23 PM
  #3086
tonyy's Avatar
i have a go tech 3 prot race with 2gallons on it with the pipe 2047. this motor was run on 30%sidewinder runs good. iam selling it i have to many motors. any ?pm me
220shipped or offers
tonyy is offline
Old 06-07-2008 | 10:25 PM
  #3087
zJatoRad's Avatar
O.S. glow plugs are good, try a #8, as for the pipe a 086 or a JP-2 should be good!
zJatoRad is offline
Old 06-08-2008 | 12:13 AM
  #3088
Tabushi's Avatar
Im using Novarossi's C4 and C5 on my .25, waaaay better performance than with the OS #8
cya,
Tabushi is offline
Old 06-08-2008 | 04:21 PM
  #3089
Dan Reino's Avatar
I have been a Die Hard OS Vspec 21 w/ 2050 pipe fan for the last 2 years. After this weekend I am a believer in Go Technology. Brian Carey w/Pro Twister Mods hooked me up w/ one of his 7 port Go motors w/ the Go Tech 0801 polished pipe. Awesome power combo. Stronger and more linear than my Vspec, and hold a very good low idle. I run OS P3 plugw/ Rocket Science 30%. If anyone has had reservations about these mills (as I have), fear not the Go Tech stuff is VERY STRONG.
Dan Reino is offline
Old 06-08-2008 | 05:25 PM
  #3090
Hi All,
I desperately need your help. My Go 3 P R, is not getting hot at all. Down the front straight its like watching grass grow, Buggies are whooping my behind. The following things I have tried without success:
Changed fuel line
Changed fuel filter
Sealed back plate & Carb
Changed carb to OS
Changed clutch from Fioroni slider to standard clutch, carbon shoes with 1.1 springs
Changed all exhaust seals
Changed all exhaust springs
Purchased a new buggy one of lighter buggies on the market, thus new fuel tank ect, ect
Problem:
The engine is almost spitting fuel, lean top end =too lean, starts to bog, back out top end, lean bottom end, I loose considerable amount of top end, down the straight you can literally make your self a cup of tea. Also engine is still tight, lock up top.
My possible solution:
Race with aluminium foil around head and try and get some heat, thus hopefully losing some of the pinch.
Note, I don’t usually use a temp gun last time I used 1 borrowed from friend, I was told brand X was notorious for false temps. I use spit and sizzle, when I spit on the head the spit just sits there, also tried pinch tech to check bottom end it’s slightly lean 3-4 seconds cuts out. I use the Ron Paris method of tuning all my engines. This motor has me completely fooled.
Thanks for all your help.
Jesussaves is offline
