Like Tree2Likes
Go-Tech Engines Thread
Old 05-22-2008 | 08:50 PM
  #2821
check your exhaust gaskets, they can do some crazy things
derricklong38 is offline
Old 05-22-2008 | 08:51 PM
  #2822
rossoh10's Avatar
I should of mentioned that I have new gaskets.....
rossoh10 is offline
Old 05-22-2008 | 08:52 PM
  #2823
skeller's Avatar
Originally Posted by rossoh10
I am having a little problem.......I have a GO 5 port with 2.5 gallons max..It idels good and has good bottom,but runs super hot and doesn`t rev out and reach top speed.....I have kinda had nothing but problems with it after the first gallon..I had to replace the carb and now this....Could it possibly be a air leak...OH and I have good trail of smoke,I just can`t figure why its running hot and not reving.Over 300
Thanks in advance
What pipe and plug are you using? And what fuel?
skeller is offline
Old 05-22-2008 | 08:56 PM
  #2824
rossoh10's Avatar
GO #5 and a OS 2060 and I have tried a 2050 also and still the same problem.I am running Byron`s 30............I use to run OS#8 and still had the same problem
rossoh10 is offline
Old 05-22-2008 | 09:11 PM
  #2825
try a cooler plug.
largeorangefont is offline
Old 05-23-2008 | 03:20 AM
  #2826
grizz1's Avatar
Originally Posted by mugenb46
if you have not got it out yet give me a call, i wouldn't suggest using a flat head screw driver, sorry grizz, just to east to tweek the sleeves like that.
615-838-5373
No worries Brian, I bow to your superior knowledge on that one In the process of breaking in a new 7 Port with Dynamite 053 for my buggy at present. Following your break in procedure as listed on page 78 of this forum.
Had a small problem getting the first tank through until I discovered I had an air leak in my fuel tubing were it connected to the tank. Now that is sorted everything is sweet. I am running flush on the HSN with head in tin foil and the LSN a little fat. Temps are around 115 - 125 deg C. If I take the foil off they drop to 100 - 105. Sound about right ?
Given my trusty 5 Port a minor overhaul, and it will now be my spare. Thought long and hard about getting a 3 Port R, but the 7 Port seems to be the weapon of choice for guys running Go-Tech's in their buggies here. The two tracks we run are fairly tight, but with longish straights and the 7 Port seems to be well suited. Can't wait to get it bedded in and give it a whirl.
grizz1 is offline
Old 05-23-2008 | 03:44 AM
  #2827
Hello PPL
I Run a 5 Port Go Tech Engine. It came with insert for normal plug, and I recently bought a Turbo insert Plug.
Can you help me and tell me how much shims should I run with Turbo Plug?
Is The Novarossi C5TC Hot plug is goog for this engine or should I use another plug?
I running 7.5 Carb insert and I'm thinking to change for the 7mm, is this ok?
Best Regards,
Bruno from Azores
BCruz is offline
Old 05-23-2008 | 03:47 AM
  #2828
vti-chris's Avatar
Which venturies work on the Go engines.
My 3 port R has the 8mm and i'm thinking on removing it completely or runing the 9mm.
What will be the performance with no venturi at all in it?
vti-chris is offline
Old 05-23-2008 | 04:01 AM
  #2829
vnmsgt's Avatar
I think performance will increase but at the same time it is going to run leaner because have more air going into motor and the same fuel as before so you might have to richen it up if the temps get too high.
vnmsgt is offline
Old 05-23-2008 | 06:03 AM
  #2830
Vigilante212's Avatar
BCruz 7 is fine thats what I run.
vti you will gain a little bit of power, but will loose run time. You shouldnt have to retune, unless its running hotter. I went from 9mm to 7mm and didnt chnge my tune at all and it runs perfectly.
Vigilante212 is offline
Old 05-23-2008 | 07:49 AM
  #2831
i wouldnt remove it completly as that would cause restriction because its not a smooth flow going into the engine without the venturi
cheesecake is offline
Old 05-23-2008 | 08:24 AM
  #2832
Is The Novarossi C5TC Hot plug good for this engine or should I use another plug?
BCruz is offline
Old 05-23-2008 | 09:48 AM
  #2833
rcrevolution's Avatar
what is the best pipe for a .21 7-port?
also does anyone have the 08 models I have been hearing about in stock?
rcrevolution is offline
Old 05-23-2008 | 09:55 AM
  #2834
zJatoRad's Avatar
Go engines run short threaded glow plugs like the OS plugs, I believe the Novarossi plugs are longer so I'm not sure if it will run alright with it, if you can get OS glow plugs, run them! P3 is what I use in my 5 Port Turbo.
zJatoRad is offline
Old 05-23-2008 | 09:59 AM
  #2835
zJatoRad's Avatar
I believe people likes to use the Dynamite 053 Midrange pipe on the 7 Port. And I think the 08 models should be in stock by now but i'm not sure.
zJatoRad is offline
